Will not crank?
Author Topic: Will not crank?  (Read 15281 times)
Offline old-school
Re: Will not crank?
« Reply #60 on: August 31, 2008 - 12:54:47 PM »
the negative battery  cable should go straight to the left cylinder head , that is the ground strap
The negative battery cable on my car goes straight to the structure that the radiator mounts to. It does not go to the block.
Offline Moparal
Re: Will not crank?
« Reply #61 on: August 31, 2008 - 12:56:35 PM »
Put that sucker on the block, then the neg ususally has a smaller wire that hooks to the screw post by the rad support along with a host of harness/light wires
Re: Will not crank?
« Reply #62 on: August 31, 2008 - 01:01:48 PM »
putting the starter load on anything less than the battery cable may have burned up a lighter guage wire or throttle cable etc
Offline old-school
Re: Will not crank?
« Reply #63 on: August 31, 2008 - 01:41:20 PM »
I'm still going through all of this information here. I probably won't be able to start back working on the car until Tuesday morning. I really don't have a clue what the fix is going to be. I don't want to pull that starter unless i'm nearly certain that's what it is. I'm going to try to load a picture of the way this negative battery cable is attached on my car.
Currently here is where i'm at. I replaced the starter relay on here as someone suggested two days ago. That wasn't it. Yesterday evening i took both wires off the starter. I bought a new positive battery cable for the car and hooked it up to the battery and spliced the smaller wire of the positive cable to the wire that goes to the relay. The long end is not connected to the starter yet as i wasn't sure if i was going to remove the starter or not.
The other wire that runs from the relay down to the starter i'd like to replace as well but i can't find one. They don't have one at the auto parts store. I was going to make one but the largest wire they had was 10 guage and this cable looks bigger than that plus it has big rubber ends on it as well so i would like to buy it. Where can i get this wire at? I didn't see it in the year one catalog or the summit catalog.
I just tried to load the picture and it says the file is too large. How do i get it to within the correct file size to load on this site?
Re: Will not crank?
« Reply #64 on: August 31, 2008 - 01:54:03 PM »
you can still buy the correct battery cable from Mopar for around $40, it comes with all 3 wires taped together
 the problem is the ground cable , if the battery cable is not attached to the engine it will not crank over , as I said the possibily now exists that you have damaged other wiring or tthe throttle cable starting the car without the neg cable attached to the engine , you need to rresize the picture smaller to load it here
Offline old-school
Re: Will not crank?
« Reply #65 on: August 31, 2008 - 01:57:50 PM »
The cable has always been grounded where it's grounded. At least since i have had it which is a little over a year. Do you think that's the problem? Why has it been working with no problems?
Offline old-school
Re: Will not crank?
« Reply #66 on: August 31, 2008 - 02:01:07 PM »
Can you or someone post a pic of exactly where your cable is grounded to the block? Is there a specific spot on the block this is there to hook the cable to? I have a 440 crate moter in mine
Offline old-school
Re: Will not crank?
« Reply #67 on: August 31, 2008 - 02:44:17 PM »
How about a link to those $40 cables. Thanks
Offline Moparal
Re: Will not crank?
« Reply #69 on: August 31, 2008 - 02:52:58 PM »
Who installed your engine?  This is a very long post on a simple subject. Not trying to be the bad guy, but it seems like basic training 101 for every little check list idea to do. I am glad to help, but wish I was there to help you. This could of been resolved by Chryco, me, Stroker or 90 % of the people here in just a mater of like 2 minutes. Neil would chime in and say 10 seconds :bigsmile:
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: Will not crank?
« Reply #70 on: August 31, 2008 - 03:18:59 PM »
It should go from the battery to the front of the head with a single bolt and small wire to the rad support.
Go to your local mopar dealer in the mopar catalog under restoration you will find the correct cables for under $40.00 they can have them by wed.
What chryco is saying is that the starter pulls a big load that small cable is too small so the electricity made its own ground through whatever it could find and may have broken(melted or fried)  something else after doing it for so long, Finley it gave out.
I hope this helps.
The good news is maybe your starter is OK.
Go Fast & Have Fun...
Online JayBee
Re: Will not crank?
« Reply #71 on: August 31, 2008 - 04:38:57 PM »
Here's a couple pictures of where it is on my 318. Also, there's absolutely no paint on the cylinder head under the bolt.
« Last Edit: August 31, 2008 - 06:55:57 PM by JayBee »
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline wally426ci
    • maryland mopars
Re: Will not crank?
« Reply #72 on: August 31, 2008 - 06:43:47 PM »
The negative battery cable is where it belongs, there should be a ground strap to the body from the engine as well....
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline old-school
Re: Will not crank?
« Reply #73 on: August 31, 2008 - 06:49:56 PM »
What? Your saying that the negative cable is ok being bolted to the radiator structure where it presently is>? The rest of these guys say the block
Offline wally426ci
    • maryland mopars
Re: Will not crank?
« Reply #74 on: August 31, 2008 - 06:55:11 PM »
Dude theres a huge 3/8" thick cable going from the engine block to the battery, then it bolts to the core support.....  :working:  :cheers:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
