Author Topic: 540 fuel consumtion  (Read 978 times)
Offline dutch
540 fuel consumtion
« on: August 29, 2008 - 01:16:14 PM »
Can anybody tell me what fuel consuption is to be expected from a 540cui mopar B1 engine?  the motor is in a b-body hooked up to a 727 and a dana 4.10 rear.  estimated horsepower; 750/800...
If one uses this car for cruizin... :violin: and an occational earthquake, what would fuelconsuption look like instead of using the same trans and rearend
hooked up to a stock 440...?
thanks, Bart
*** Bart ***
Offline Carlwalski
Re: 540 fuel consumtion
« Reply #1 on: August 29, 2008 - 01:22:10 PM »
Don't buy it. If you are already asking then pass it up. ;)
Sorry but I just don't get these questions. It's 540 cubes of MoPar, if you have to ask then it's not for you.
 :2cents:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 73challenger_TN
« Reply #2 on: August 29, 2008 - 01:34:44 PM »
Umm I'd say somewhere between bad and horrible.  :) People with 540s don't care about mileage.
Offline dutch
« Reply #3 on: August 29, 2008 - 01:47:26 PM »
 :2cents:
 :biggrin:  I won`t buy it....I`ve got my hands full with my 440...just asking for a friend.   But .... with fuel costs at about 9.50 a gallon I still think it does make sense to ask this question...
Sure 540 `s are thirsty but a 440 is thirsty too.  but if a 540 takes twice as much fuel .... :eek4:
*** Bart ***
Offline 71bigblock
    • Steve's Mopars
« Reply #4 on: August 29, 2008 - 02:00:42 PM »
I hear ya.  I think your buddy and you are just wondering how much it will take compared to a stock 440, right?  Valid question.
I'd guess take half of what a 440 uses, and add it on to the total.  So like 1.5 times the fuel.  Just a wild guess.
Offline NoMope Greg
« Reply #5 on: August 29, 2008 - 02:01:54 PM »
Well, 800 hp is up there in NASCAR territory, only with a big block.  Those guys get about 4 mpg at 180 mph, but in a much more aerodynamic body and with ALL the best flow bench testing, carb tweeking, thermal coatings, etc.  I'd be surprised if it made it to 10 mpg - I'd expect about 7.  But like Carl said - if he has to ask the question, why is he buying it anyway?  At $9.50/gallon, it should be toy.  Mine's a toy (well, will be) at $3.75/gallon.  That's why I have the UAV.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline 71chally416
    • The Streetwalker
« Reply #6 on: August 29, 2008 - 02:21:38 PM »
You can expect about 80 miles per tankfull if you drive it carefully  :2thumbs:
Offline 67vertman
  • Member since 9-23-2005
« Reply #7 on: August 29, 2008 - 11:07:22 PM »
We need Oldschool to speak up.  His car would probably get the same as the 540.  My guess is in the 3 to 5 MPG range.  Where a stock to mild 440 would be in the 10 to 12 MPG range.
It also depends on how heavy your right foot is.. :burnout: and how many carbs you have.  :2thumbs:
« Reply #8 on: August 30, 2008 - 01:13:20 AM »
iot can be tuned to get milage & if the driver can keep out of the loud pedal but it still really depends on the build of the engine too , it could easily see as low as 1/2 mile / gal up to mid teens
Offline dutch
« Reply #9 on: August 30, 2008 - 02:12:08 AM »
thanks gentlemen,
I`ll forward so my friend can make up his mind  :2thumbs:
*** Bart ***
nivvy
« Reply #10 on: August 30, 2008 - 03:35:14 AM »
I will be about 750HP with my new indy setup and my full port eddy rpm setup I got 2.1 miles to the gallon about 40 miles to the tank....  :scared:
but who cares.....  :lol2:
the reason for my crappy mileage is because i was down in 1 all the time with the MVB up on the converter wait for takers.....  :burnout:
but like I said... dont care about gas....  :2cents:
