Author Topic: 17" magnums  (Read 10721 times)
Offline kslush
17" magnums
« on: August 29, 2008 - 02:26:53 PM »
I am possibly looking to run 17" magnum wheels on my '70 cuda and was wondering if anyone else has these.  If so can you post a pic so I can have a rough idea of what it looks like?
Also, what tire sizes are you guys running with your 17" wheels?  I was thinking 275/40/17 for rear and 225/45/17 for front.  I am a little worried that the side walls will be too small.  Thanks in advance.
Offline drewcrane
Re: 17" magnums
« Reply #1 on: August 30, 2008 - 07:00:00 PM »
im running 255 / 40 zr 17,on an 8 inch wheel,4 inches of backspacing,
 make sure you check the actual measurements for what ever manufacturer you chose as they vary from company to company. :popcorn:
Re: 17" magnums
« Reply #2 on: August 30, 2008 - 07:51:42 PM »
hope your talking about the aluminum type....consinsus is that the all steel 17" magnums would be too heavy
Offline drewcrane
Re: 17" magnums
« Reply #3 on: August 31, 2008 - 09:54:08 AM »
too heavy,i hope they are alloy, when ever someone puts bigger wheels on there car they are adding unsprung weight, as a 15 in wheel will weigh lets say 30 lbs, a 17 inch wheel will weigh about 5 to 7 lbs heavier!i have 22,s on a ford and they weigh with tire 98 lbs!each :popcorn:
Offline kslush
Re: 17" magnums
« Reply #4 on: August 31, 2008 - 05:13:31 PM »
drewcrane, can you post a pic of your car with those tires?
bullit, no worries I don't plan on putting 17" steel wheels on my car.
Offline autoxcuda
    • Spring Fling
Re: 17" magnums
« Reply #5 on: September 01, 2008 - 04:29:11 AM »
With a 17" rim you can run up to 5.5 of backspacing up front. Sometimes more with proper fitting. That would give you more tire to fender clearance for someone that wants to run more sidewall like a 245/45/17 or more like a 245/50/17
Read here: http://www.moparfins.com/CLAIRDAVIS/Cobra_Wheel.htm
I know this is a 69 Valiant, but he runs the 73-74 E-body/73-76 A-body spindle. Actually the Upper and lower ball joints have the same part numbers from E-body to late A-body. The clearance to the upper ball joint, spindle, lower ball joint will be the same as your E-body
I know you can run 4.5 backspacing in the rear of an E-body. I think 5" is doable with offset hangers?
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
Offline drewcrane
Re: 17" magnums
« Reply #6 on: September 01, 2008 - 10:45:35 AM »
here is a pic with 17x8 inch wheels :bigsmile:
Offline 422STROKER
  • Member Since 6/3/06
Re: 17" magnums
« Reply #7 on: September 01, 2008 - 10:49:50 AM »
There is a section here somewhere that has more pics of tires and wheels.
Here is a shot of mine with 245/45/17 F and 255/45/17 R.  17x8 with 4.5 bs
Haven't seen any with the 17" Magnums though. I think there was someone with some 20's here a while back.
Tom :2thumbs:
By tdavist, shot with DSC-P72 at 2008-04-30
Tom
Offline hemiken
Re: 17" magnums
« Reply #8 on: September 01, 2008 - 11:05:38 AM »
here is a members 'Cuda with 17" Magnums installed. :2thumbs:
Offline IMNCARN82
  • LeDZeP
Re: 17" magnums
« Reply #9 on: September 01, 2008 - 02:57:07 PM »
I like those!!   :bigsmile:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline TKat13
  • Work In Progress...
    • Project Cuda
Re: 17" magnums
« Reply #10 on: September 01, 2008 - 11:53:09 PM »
here are some pics of magnums on a 72-74 Challenger that I took at Carlise in 2005. They were 245/45/17 up front and 275/40/17 in the rear. Hope this helps.
« Last Edit: September 01, 2008 - 11:55:51 PM by TKat13 »
1974 'Cuda
2005 SRT-10 Ram
2006 Buell Firebolt XB12R (Murdered by person texting & driving)
2004 Mach 1
Offline ChallengerGary
    • Challenger Gary
Re: 17" magnums
« Reply #11 on: September 02, 2008 - 11:26:27 AM »
  :wow:  I think those may be my favorite 17" rims yet!
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline black71
  • eph 6:12
Re: 17" magnums
« Reply #12 on: September 02, 2008 - 11:54:35 PM »
 :droolingbounce: WOW some beautiful cars i love that oronge 'cuda!
 drewcrane any more pics of your car?
Offline 72bluNblu
Re: 17" magnums
« Reply #13 on: September 03, 2008 - 01:32:43 AM »
Not always true, it depends on the wheel. I had 17x8" rims on my SRT4 that weighed 15.6 pounds each and were almost 5 pounds lighter than the stock 17x6" wheels. The type of wheel is more of a factor on the weight, high performance or race bred 17" aluminum wheels may actually weigh less than the stock 15's.
Offline kslush
Re: 17" magnums
« Reply #14 on: September 03, 2008 - 07:28:28 AM »
Thanks for the pics guys.  That helps a lot.
