Author Topic: need help putting motor back together.  (Read 798 times)
Offline 73james
  • horsepower and torque are only the beginning
« on: August 29, 2008 - 05:39:25 PM »
 :swear: I need a picture of a scan of the front of a 340 73 challenger motor. I do not remember hbow to put the water pump and stuff on from there. So i need help from water pump on with the size bols and how things go back on. can anyone help?
Thanks
james
Offline wally426ci
    • maryland mopars
Re: need help putting motor back together.
« Reply #1 on: August 29, 2008 - 06:09:15 PM »
heres my 360, same thing basically....  :2thumbs:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 73james
« Reply #2 on: August 29, 2008 - 06:57:57 PM »
cool. thanks. Do u think u know the bolt sizes of the water pump? i have bolts but dunno know where they go.
Thanks
73james
Offline wally426ci
    • maryland mopars
« Reply #3 on: August 29, 2008 - 07:05:06 PM »
the problem is that most of them are pretty long. the 2 at the bottom of the water pump are SHORT!!! they only thread into timing cover. A certain someone I know threaded a bolt that was too long and cracked his Cam timing gear, and found out after he cranked the motor....  :misbehaving: I only see hime when I look in the mirror... wierd.  :pullinghair:
anyway, I know that the heads are all 9/16"
I will also say, take a close look, there are a few bolt holes you cant get to when the water pump is on.  :working:
Good Luck!  :cheers:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 73james
« Reply #4 on: August 29, 2008 - 07:35:00 PM »
thanks. I got most of it together now. But I need to wait for the paint to dry no so I can work on it more. OHHHH question do you know if there is a bracket that is supposed to go on the right side of the water pump? Thanks for all the help.
Thanks
73james :working:
« Reply #5 on: August 30, 2008 - 12:52:39 AM »
if you have power steering there are brackets that go on the drivers side of the engine & timing cover for that as well , sorry no pix though
