Author Topic: soldering 1/4 return line  (Read 2037 times)
Offline 71chmark
« on: August 29, 2008 - 05:43:23 PM »
I need to plug the 1/4 inch hole for the return line in my new 3/8 sending unit. From other threads I have read it seems like soldering is the way to go.  I've soldered wires but never a hole.  It seems as if the solder would just run down the tube unless I just filled it up to the bend I suppose.  Can anyone give me guidance on how to plug my hole?  That doesn't really sound right does it?
I may be schizophrenic,
Offline leithal
Re: soldering 1/4 return line
« Reply #1 on: August 29, 2008 - 05:58:36 PM »
that's disgusting.
Offline wally426ci
    • maryland mopars
« Reply #2 on: August 29, 2008 - 06:06:25 PM »
is it another "nipple"?? you could just stick a vacuum cap on it.......  :dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 71chmark
« Reply #3 on: August 29, 2008 - 06:29:24 PM »
Seems like it would leak fuel out a vacuum cap when fuel level was above the sending unit base.  It is a nipple and goes through the sending unit base and ends after a short turn. I suppose I could put a screw in it and solder it closed.
Offline wally426ci
    • maryland mopars
« Reply #4 on: August 29, 2008 - 06:53:02 PM »
Ive done the old, Bolt in a rubber hose trick and it had never leaked. of course, thats usually in junk cars up near the fuel pump, but hey, i think it would work.....  :dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Katfish
  • 70 Challenger
« Reply #5 on: August 29, 2008 - 07:09:23 PM »
How about using some solder braid as a patch to fill the area.  Once you get the sides staked, you can fill the middle.
Offline 71chmark
« Reply #6 on: August 29, 2008 - 07:52:44 PM »
Solder braid?
Offline Katfish
  • 70 Challenger
« Reply #7 on: August 29, 2008 - 08:34:19 PM »
It's basically copper mesh, it's normally used to wick solder away.  Once filled with solder it basically will become a solid.
http://www.radioshack.com/product/index.jsp?productId=2062744&cp=&sr=1&kw=solder+braid&origkw=solder+braid&parentPage=search
« Last Edit: August 29, 2008 - 08:36:15 PM by Katfish »
Offline 422STROKER
  • Member Since 6/3/06
« Reply #8 on: August 29, 2008 - 09:19:30 PM »
I just put a short hose on it and a bolt for now.  No leaks at all.  I need to route this up to the vent set-up though.
Tom
By tdavist, shot with DSC-P72 at 2008-05-25
Tom
Offline drewcrane
« Reply #9 on: August 30, 2008 - 11:02:31 AM »
dont solder that , like they said put a hose on it and clamp it, you or someone else might use it later, i have to have a return line on my car for vapor lock problems, it gets hot here, maybe you should just hook up  a return line. :popcorn:
« Reply #10 on: August 30, 2008 - 11:53:35 AM »
cap it
Offline 72bluNblu
« Reply #11 on: August 30, 2008 - 12:06:46 PM »
Vacuum caps won't work, the fuel will eat the rubber if you ever fill the tank above the level of the sending unit. Soldering wasn't all that hard, since its low temperature the solder doesn't really run all the way through, as it moves away from the end and the solder gun it hardens up and plugs the hole (if you keep the heat down). It took me a couple of tries, but worked fine once I figured out you can't just do it all at once. Solder a little at a time, giving the solder the chance to harden and the tube to cool a little and its no problem. As for needing it again, the solder can be melted out pretty easily, which you'll notice if you bring in too much heat with the soldering iron, all the solder runs out and you have to start over...
Offline 71chmark
« Reply #12 on: August 30, 2008 - 02:56:58 PM »
Well I just did what Challorange did with a bolt, hose and a couple of clamps.  The whole job took 40 minutes from start to finish and now my gas guage works.  Yahoo.
Offline 422STROKER
« Reply #13 on: August 30, 2008 - 03:25:48 PM »
Simple but effective.
Tom :2thumbs:
Tom
Offline drewcrane
« Reply #14 on: August 31, 2008 - 09:58:24 AM »
all the solder runs out,isnt that the truth,well im glad that works for you and your car, as all cars, owners, and applications are different,its good info for me to know in the future! :cheers:
