Author Topic: Clutch Problem  (Read 4834 times)
Re: Clutch Problem
« Reply #15 on: January 11, 2009 - 01:40:11 PM »
try lengthening the rod some more to push the pedal back further
 if it still slips under power something else is wrong
Offline vinb
Re: Clutch Problem
« Reply #16 on: January 11, 2009 - 02:38:16 PM »
It sounds like you need to re-adjust the clutch to get it pass center, but I would first make sure you have the correct fork & adjuster rod in there...
I adjust my clutch just so the bearing is barely off the fingers on the plate (maybe .010's)and I check it with the engine running (just don't stick your hands in there).
Re: Clutch Problem
« Reply #17 on: January 12, 2009 - 02:34:39 AM »
also make sure the bushings inside the Z bar are in good condition , if the Z bar is loose you will have problems as well
Offline 72 cuda
Re: Clutch Problem
« Reply #18 on: January 12, 2009 - 04:23:05 AM »
Dear sleepy,
If you are slippjng in a higher gear, with a new clutch, your clutch is probably partialy engaged, check your linkage. 1/4" play with clutch released at clutch fork is a general rule. But Chryco will know the correct clearance, more than me.
Mark
sleepychallenger
Re: Clutch Problem
« Reply #19 on: January 12, 2009 - 07:38:50 AM »
bushings are new. i will try adjusting this weekend
