Author Topic: Oil pan ID help  (Read 727 times)
bbscamp
Oil pan ID help
« on: August 30, 2008 - 06:07:33 PM »
I"ve got a F body with a slant 6.  If going with a SB engine swap, what oil pan do I use?  An "A" body?   IF a BB swap, what oil pan?   I've got that 69 440 prepped for a B/E, so I'd have to swap pans...
heres the car, rallys next, then dump the slant.
Re: Oil pan ID help
« Reply #1 on: August 30, 2008 - 09:26:53 PM »
I think most the small block pans all are about the same and should fit. Like the a/e body. I believe you may need a 187 or 933 bb pan for the steering link clearance
Re: Oil pan ID help
« Reply #2 on: August 31, 2008 - 01:56:11 AM »
I think Schumaker has a mount kit for this as they are a problem to get a bb mounted in there , pan clearance could be an issue as the K & steering are different
