Water inside one of the tires?
center section picking up old gasket material in the oil as you are running?
Pinion nut a little loose
Ubolt shakle nuts not tight
A shock going bad or the bolt is loosening up on top
Transmission mount bolt loose a bit
Brake adjuster wheel not adjusted and dragging the brakes causeing dust bumps
The road just happened to really suck in that certain spot at the time
Passenger motor mount loose
tortion bar creeping back in the hole ( hope the clips in)
Sway bar bushings not tight
Sway bar mount to frame loose
Exhaust bracket bad
Exhaust pipe touching on frame or tq rods
Im running out of ideas
