Author Topic: HP manifold differences?  (Read 775 times)
Offline AMXguy
« on: September 01, 2008 - 08:21:07 PM »
I'm so impressed with the TTI exhaust system I put on my 440 Challenger I want to do the same with my new project. on this my RH side  manifold is a '70 HP and my LH one is a '68 HP, will the exhaust system bolt up the same or am I going to have a mess with two different year manifolds?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: HP manifold differences?
« Reply #1 on: September 01, 2008 - 08:24:12 PM »
The right is about the same 68 69 70 71 but the drivers side e body is twisted just a tad in 70 71. It will work though, I did a 68 drivers on my e body with yearone. It was easy enough to tweak with no tools needed. Just a bit of prying with my arms. I am not a big guy either :cooldancing:
« Reply #2 on: September 01, 2008 - 08:35:27 PM »
let TTi know the #s off the manifolds when you order it & you will get the right parts
Offline AMXguy
« Reply #3 on: September 01, 2008 - 08:39:38 PM »
I never though about that, you're right they do ask for your manifold part #'s.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #4 on: September 01, 2008 - 09:06:50 PM »
when I do they ask for manifold #s
