Small Block “A” body? clutch fork, pivot, adjuster, Torque shaft
Author Topic: Small Block “A” body? clutch fork, pivot, adjuster, Torque shaft  (Read 591 times)
Offline ohio cuda
Can anyone use these items? I took them off a 1970 340 Cuda I’m working on and I believe them to be for a Small Block “A” body or truck. They will not work on a 340 Cuda unless you bend the exhaust pipe into a pretzel. The clutch fork is 12-1/2” long. You probably have a couple hundred dollars here buying from a dealer. Is $100.00 too much for our members and you pay the shipping? The box weighs about 5 lbs. I can take more pictures and measure if you require. All parts are clean and ready to install.
