Author Topic: Acc pump spring  (Read 1179 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Acc pump spring
« on: September 06, 2008 - 03:35:03 PM »
I recently cleaned out my eddy 800 AVS and after that I never got it to work properly. It stalled and acted very weard.
Now I found that I forgot to put back the spring for the acc pump, the one in the carb pushing the pump upwards.
Could this be the reason I had problem with it?  :clueless:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline 71chally416
    • The Streetwalker
Re: Acc pump spring
« Reply #1 on: September 06, 2008 - 03:59:18 PM »
I suppose so, unless they put it in there for no reason.  :clueless:
Re: Acc pump spring
« Reply #2 on: September 07, 2008 - 02:00:29 AM »
I doubt it will fix the problem but it needs to be in there
Offline oldkimmer
Re: Acc pump spring
« Reply #3 on: September 07, 2008 - 09:09:57 AM »
...........................U got it............kim..........
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Re: Acc pump spring
« Reply #4 on: September 17, 2008 - 03:31:38 PM »
No difference with the spring back, what kind of damage could the water in the carb have done? It was new.
Offline Supercuda
Re: Acc pump spring
« Reply #5 on: September 17, 2008 - 07:47:15 PM »
If the water was in there long enough to grow "white fuzzies" on the aluminum inside the carb, then it is possible that the smaller passages in the fuel circuits are also blocked. Thin wire and careful inspection of every part of the carb that flows fuel, will help you determine the extent of the damage, and whether it is repairable. Otherwise, it sounds like a simple tuning or installation issue (gasket on wrong, bad vacuum caps, that kind of thing).
Re: Acc pump spring
« Reply #6 on: September 18, 2008 - 01:43:01 AM »
what symtoms is the engine having ?
Re: Acc pump spring
« Reply #7 on: September 18, 2008 - 03:26:33 PM »
Will continue in "camlobe wear".
