Author Topic: Detailing Question  (Read 1180 times)
Offline troutstreamnm
Detailing Question
« on: September 06, 2008 - 10:08:08 PM »
I need to get a good coat of wax on my car and wondered about the vinyl stripes and hood blackout.  Should you avoid getting wax on these areas or just wax away? Thanks.
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline 422STROKER
  • Member Since 6/3/06
Re: Detailing Question
« Reply #1 on: September 06, 2008 - 10:29:57 PM »
I didn't wax the stripes on mine.  Patience is key when doing this.LOL
Tom :2thumbs:
Tom
Offline resq302
« Reply #2 on: September 06, 2008 - 10:35:27 PM »
Actually, you can wax stripes.  The only thing you have to be careful is to NOT wax things that are flat or semi flat black as it will leave a white chalky type film on it.
Offline 422STROKER
« Reply #3 on: September 06, 2008 - 10:42:24 PM »
Mine are not shiney for sure.
Tom :working:
Tom
« Reply #4 on: September 07, 2008 - 03:24:29 AM »
Certain waxes don't dry to a white haze, so you can wax your gloss stripes without any problem. If you do use a wax that dries white, you'll need to use your finger nail when wiping the wax off around the edges of the stripes. That's what I do.   :eek4:
« Reply #5 on: September 07, 2008 - 10:58:42 AM »
Thanks for the input.   :2thumbs: Mine are flat black so I'll try to avoid the areas just to be safe.
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline resq302
« Reply #6 on: September 09, 2008 - 02:10:48 PM »
Or you can use a detail trick that I found, try putting blue painters tape on the stripe to prevent the wax from getting onto it, then peel the tape off.  No mess, no wax on unwanted parts.
« Reply #7 on: September 09, 2008 - 02:18:59 PM »
MEK didn't I tell you the trick about using a soft tooth brush? Did it work?
Besides, what would you do if you just cut your fingernails?
« Reply #8 on: September 09, 2008 - 05:37:00 PM »
I didn't use the tooth brush.  :banghead:
Let me tell you, I did one fine job, but I had some sore fingers after I was done.   :faint:
