Author Topic: 75 amp alternator  (Read 1527 times)
Offline 71cudda
75 amp alternator
« on: September 06, 2008 - 10:43:37 PM »
i just installed a 75 amp powermaster alt in my 440, i was told to run a 10 gage or heavier charge wire from the alt directly to the battery. is this correct for an externally regulated system, as i thought everythig had to go through the regulator first.will that wire going directly from the alternator to the positive terminal cook my battery. also, if it is ok to run it like that, do i run the wire from the same stud that the harness wire is coming off of       thanks
Offline ted
  • 74 cuda, 70 challenger r/t
Re: 75 amp alternator
« Reply #1 on: September 06, 2008 - 11:06:44 PM »
that is fine that way. the power  DOES NOT  go thru the regilator.
Offline 71cudda
« Reply #2 on: September 06, 2008 - 11:11:31 PM »
thanks
« Reply #3 on: September 07, 2008 - 01:36:15 AM »
that will work , I just connect to the the large terminal on the starter relay
Offline pink panther
« Reply #4 on: September 07, 2008 - 12:44:27 PM »
did you get the chrome one?  I istalled one on my chally last year, works fine.
« Reply #5 on: September 07, 2008 - 01:13:02 PM »
With 75 amps, I don't think it's necessary to add the wire from the alternator to the starter relay, but it is most definitely the safe way to go.   :grinyes:
