Author Topic: Chilly Challenger painted - need more help!!!  (Read 54280 times)
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
Re: Chilly Challenger painted - need more help!!!
« Reply #90 on: January 21, 2009 - 08:23:16 PM »
Thanks!! - I'll get the exact name and brand off the can.
Offline elitecustombody
  • Supra collector
« Reply #91 on: January 21, 2009 - 11:12:35 PM »
for future refference,there is clear texture coating ,also why didn't you use a good coat of primer before spraying white? if you are still having hard time covering with white,let me know
Stefan B
Offline carguybradd
« Reply #92 on: January 22, 2009 - 01:15:34 AM »
Interesting method for retextuing the door panels. I have to ask, what material did you use to fill in scratches (and/or the seams where you made the repair in the corner)?
1970 Challenger Western Sport Special
(B7 blue,white top,blue int.,318/904 - for now)
1973 Duster
(B5 blue,black & white int.,340/727)
1966 Chevy C-10 short/fleetside
1965 VW Beetle
2006 Grand Caravan SXT (for the wife...)
Offline e-tek
    • E-Tek Resto's
« Reply #93 on: January 25, 2009 - 11:05:18 AM »
What was the brand that you went with for coloring your panels? :clueless: And what was the colr name? They look great, I want to get some of the same and paint my panels as well. :2thumbs:
Krylon Plastic Paint - Sail White. Thanks!!
Offline e-tek
    • E-Tek Resto's
« Reply #94 on: January 25, 2009 - 11:11:15 AM »
Thanks! The only clear "texture" coating I'm aware of (and I called 3 supply houses) is a chip-gaurd for lower panels - I was going to use this, but the texture is too smooth for what I wanted. The reason I didn't use a primer on plastic is that you're supposed to use an adhesion promotor that softens the initial substrate instead. Adding another layer would also be another color and material. SEM recommends spraying your topcoat over the original material, regardless of color - although I know what you mean and that's what I would have done on a bumper repair - so I don't know!!
After using the SEM "Crest" white, the Krylon Sail-White covered well - so back to using a primer...I guess I did...
Offline e-tek
    • E-Tek Resto's
« Reply #95 on: January 25, 2009 - 11:18:19 AM »
I used a two-part flex bumper repair material (and a little 2-part final filler for the finer scratches...sshh!!). The "problem" with this method is finding the right texture....nothing matches the original exactly. The clear texture mentioned in the last post was too smooth (IMO) and a truck box texture I found was too "sharp". I tried SEM's texture, which laid down like flat black paint...and then Sur-Tex, which was closest, but still not exact. The best thing I guess would be to spend $600.00 on new panels...I spent nearly 150.00 in materials - and maybe 30-40 hours....so it's anyones call.
Offline carguybradd
« Reply #96 on: January 25, 2009 - 09:40:28 PM »
Thanks for the info! The putty I used on mine has begun to crack, so the flexible bumper repair material sounds like the ticket! My panels are too good to toss (just a few scratches), and a weird color (blue), so this just might be the answer for me. :cheers:
1973 Duster
1965 VW Beetle
Offline e-tek
    • E-Tek Resto's
« Reply #97 on: May 06, 2009 - 09:57:04 PM »
Hey Guys, haven't posted an update in a while, so thought I'd do so now. Just buttoning up a few undercarriage detaisl (tank, lines) before repalcing the mill! Stayed with the original 14" rims becuase they wanted 900.00 to transfer my rings to 15" bells....shod them with 215/60's BFG's.
Won't be long now!!!  :cooldancing: Crusin' this summer!! :ylsuper:  Thanks for looking!!
Offline e-tek
    • E-Tek Resto's
« Reply #98 on: May 07, 2009 - 02:02:43 AM »
Here's a PR shot of my wife, who races IP-2 class. She also can't wait for the Challnger to be ready!
Offline wally426ci
    • maryland mopars
« Reply #99 on: May 07, 2009 - 12:03:25 PM »
Lookin good!!! those panels turned out nice!  :wave:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline femtnmax
« Reply #100 on: July 27, 2009 - 09:26:45 PM »
Your doing excellent work.  Nice attention to detail.  Is the outside W1 white?   The color white is timeless, it will be in-style throughout generations.    :2thumbs:
The interior turned out real well.  Good to see you stuck with the upholstery problems to correct the flaws, and thanks for posting all the pics of detail work.
Had to laugh about the 240Z.  I was a factory trained Datsun mechanic back when the 260z was on the showroom floors.  They are a fun car, and I assume alot cheaper to build than a Challenger.
My Challenger will be a true driver.  I see your sort-of just north of Montana.  Give me a year, and when I get the challenger running I could travel your way to share stories.  I'm also hoping to drive the dodge to Alaska to visit a friend who has a '66 GTO thats the 9th one built that year!
Phil
Offline e-tek
    • E-Tek Resto's
« Reply #101 on: August 02, 2009 - 10:46:36 PM »
Hi Phil,
Very cool Datsun expereince!
Yes, it's W1 White. I found it a little grey when it was going on - it's not the "brightest" white for sure. But it looks OK with black accents. Where are you? We're actually just North of N. Dakota. Closest is Minot.
Good luck with your Chally - what's the link?
« Reply #102 on: August 10, 2009 - 10:46:23 PM »
Looking great!!! :2thumbs:
Offline e-tek
    • E-Tek Resto's
« Reply #103 on: August 11, 2009 - 12:32:35 AM »
The engine RUNS!!!!!!
Not sure why it doesn't embed here....but just click the first link within that papragraph below and it'll open a new window...
<object width="640" height="505"><param name="movie" value="http://www.youtube.com/v/iNP4GHoyahU&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/iNP4GHoyahU&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object>
« Last Edit: August 11, 2009 - 12:34:15 AM by e-tek »
Offline 4THECHALLENGE
« Reply #104 on: August 14, 2009 - 02:47:15 AM »
Fa :burnout:ntastic work and attention to details...
