Kowalski,
Here is a formula to calculate your rear end ratio:
(Tire diameter)*(RPM)/[336.14*speed]=(rear end ratio)
Where tire diameter is in inches, speed in miles per hour.
This is for top gear only, (1:1). If you wanted to use this for another gear, you would have to stick the transmission ratio for that gear in the denominator also.
Hope that helps.
