Author Topic: Power Steering Box in my Dads 74 Barracuda, replace seal or...??  (Read 2964 times)
Offline wally426ci
    • maryland mopars
« on: September 11, 2008 - 07:55:53 AM »
Is there a way to replace the shaft seal where the Pitman arm attaches? or should i be shopping for a new replacement...? Would they have this at Autozone or some place?
 :feedback: <-- BTW, I dont like the Angry eyebrows on this guy......
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Power Steering Box in my Dads 74 Barracuda, replace seal or...??
« Reply #1 on: September 11, 2008 - 09:50:14 AM »
you can replace the seal , thread in a couple of drywall screws , pull the seal or it is a great excuse to upgrade to a Firm Feel unit
Offline quagmire
  • Traction Impaired......
« Reply #3 on: September 12, 2008 - 01:30:28 AM »
My personal favorite way of doing these seals is to first remove the pitman arm and snap ring, then start the car and turn the wheels to the locks a couple of times.  The pressure should blow the seal right out of the box for you.  Just make sure you put a drain pan under it.....
Offline Ford.P51
« Reply #4 on: September 12, 2008 - 08:38:25 AM »
If you decide to shop for a replacement gearbox, maybe this will help. I replaced the power gearbox on our 72 Challenger last weekend using unit purchased from Napa. It was a perfect match and went in fairly easily. The only trouble I had was there was too much paint on the shaft that the steering column slides onto, I had to remove some of the paint to get the splines to go all the way on. At the time Advance auto and Autozone listed a part on their websites but could not order one, their supply was empty.
1969 Ford Mustang Mach1
1972 Challenger
Offline wally426ci
    • maryland mopars
« Reply #5 on: September 12, 2008 - 02:13:37 PM »
Sweet! do i have options. How much did the Napa box cost? How about the Firm Feel unit cost wise?  :cheers:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Ford.P51
« Reply #6 on: September 12, 2008 - 02:32:07 PM »
If I recall correctly the Napa unit was $145 with shipping plus a $75 core charge. Its a rebuilt box.
The steering is now fantastic on the car, not only did it fix the leaks, but there is no play in the wheel at all. I was very pleased.
1972 Challenger
Offline wally426ci
    • maryland mopars
« Reply #7 on: September 13, 2008 - 06:59:56 AM »
Hmmmm..... I think I may go this route possibly. I owe hime for helping me so many times anyway..
What about Rack & Pinion steering? has anyone converted to that?  :chatting:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline RaptorF229
  • A work in Progress
« Reply #8 on: September 13, 2008 - 11:55:32 AM »
I ordered the firmfeel unit this week. 375 for the box and 175 core.
« Reply #9 on: September 13, 2008 - 01:00:18 PM »
doing rack & pinion is involved , if you go rear steer as per factory you have oil pan clearance issues so the rack needs to sit lower , if you go to front steer the you need a different spindle & I have yet to find a good one , in both cases generally you need to go to a tubular K frame as well unless you make some strong brackets off the factory K for rear steer, you will also need to modify the steering column to get enough flex to get to a rear or front steer rack
Offline wally426ci
    • maryland mopars
« Reply #10 on: September 13, 2008 - 01:28:50 PM »
Ahh screw that, he hasnt driven the car in almost 2 years anyway....  :misbehaving:
Thanks Chryco, you da man.
I saw a conversion from some place for $1400 but i suppose its more involved...  :working:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
