car over charging?
Author Topic: car over charging?  (Read 985 times)
Offline scf100
  • FAST LANE FOREVER!
car over charging?
« on: September 11, 2008 - 08:43:01 PM »
have a new alt, volt reg etc...been on over a year..
lately my gauge is showing the charge needle way over the top of charging at times......then it will bounce back to the middle...
what do you think?
1970 Challenger R/T convertible 383…. 4-speed…3.91 suregrip
Triple Black
Offline GoodysGotaCuda
Re: car over charging?
« Reply #1 on: September 11, 2008 - 08:49:22 PM »
Possibly loose connection at the alt, bulkhead or voltage regulator. I have also gone through many auto parts store voltage regulators before I got to the one i've had for about 2 years now. They do fail quite often.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Supercuda
« Reply #2 on: September 11, 2008 - 09:50:34 PM »
The loose connection is probably at the battery cable ground on the engine. It is definitely a connection issue, and is usually either the spade terminal on the fuse link (dirty or loose connection), or at the ground on the engine. If you tried to make the connections look better by eliminating any washers, or painting the block and putting the cable right against the paint, then this will likely be it. On my car, the addition of a star washer under the cable end on the block fixed all. Every time I checked my connections, I got good readings (no resistance), but it would constantly pull the overcharge/normal trick. In frustration, I pulled the ground for cleaning of the interface between it and the engine, and said, "What the hell, I will put the washer on- I have one now." I immediately cured the problem. Apparently, the connection was excellent every time I checked, and lousy every time I turned my back.
