Author Topic: 4 SPEED TRANS  (Read 955 times)
Offline 383DART
4 SPEED TRANS
« on: September 12, 2008 - 12:16:14 PM »
I PURCHASED A 1972 CUDA WITH NO TRANS. IT HAS A 340 ENG. IS THERE ANY DIFFERENCE BETWEEN A SMALL BLOCK OR BIG BLOCK 4 SPEED TRANS. ARE THERE ANY VENDORS SELLING 4 SPEEDS.  THANK'S.
Re: 4 SPEED TRANS
« Reply #1 on: September 12, 2008 - 12:22:59 PM »
no difference to a point , the 440 & Hemi had a 18 spine heavier version but the lighter 23 spline will bolt up , the blehousing is different for small & big blocks & there are 2 versions , long & short tailshaft , only the later long shaft will fit an E body + it has to have the dual shift mount pads
 Brewers Performance  sells rebuilt units & belhousings as well
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: 4 SPEED TRANS
« Reply #2 on: September 12, 2008 - 12:23:42 PM »
The only difference is the bearing size between a big block and small block 4 speed but either will work. There is alos a hemi 4 speed that will work as well but is a lot more money. The main difference between the standard and hemi 4 speeds is the input shaft on the hemi 4 speed is an 18 spline versus a 23 spline. Passon Performance and Brewers both rebuilt transmissions as well as many other parts for 4 speed cars.
1996 Dodge Viper GTS Coupe
Offline Pistol Gripper
Re: 4 SPEED TRANS
« Reply #3 on: September 12, 2008 - 01:14:21 PM »
383DART,
Welcome.  Where are you located ?  There are vendors out there like http://www.brewersperformance.com/default.htm that sell rebuilt trannys.  I happen to live close to Brewer's and they are great to deal with.
P.G.
O ne
B ig
A $$
M istake
A merica
sleepychallenger
Re: 4 SPEED TRANS
« Reply #4 on: September 12, 2008 - 01:31:32 PM »
is the z bar different?
Offline 72hemi
Re: 4 SPEED TRANS
« Reply #5 on: September 12, 2008 - 01:44:47 PM »
Not between the big and small block, but I do believe the body style may make a difference. Below are two more links of places that have 4 speed parts.
www.passonperformance.com
www.manciniracing.com
Offline 383DART
Re: 4 SPEED TRANS
« Reply #6 on: September 13, 2008 - 08:49:50 AM »
 :THANK'S FOR ALL YOUR HELP. I AM EAST OF CLEVELAND OHIO.
