Lots misc parts for sale
Author Topic: Lots misc parts for sale  (Read 798 times)
« on: September 13, 2008 - 03:26:10 PM »
Big list for your review. Check it out and contact me if you want to see pictures of anything. You pay shipping on most items. highplains@comcast.net
list
$300.00   66-70 B body clutch pedal assy, rebuilt
$150.00   66-70 B body clutch pedal assy, needs rebuilt
$115.00   B/E adju strut
$115.00   B/E alum strut
$80.00   66-70 B 4spd tunnel cover, used
$75.00   adj pinion snubber 8 3/4
$65.00   alum shackle bushing
$50.00   OEM disc brake spindles
$50.00   Super Bee Emblem — Grille (1969 Super Bee)
$50.00   Clutch Linkage Shaft Service Kit (B- and E-Body)
$50.00   SB tall throttle bracket
$50.00   low deck big block tall throttle bracket
$50.00   W2 tall throttle bracket
$50.00   Abody  Lwr arm poly pivot
$50.00   RB block tall throttle bracket
$50.00   axle shim set
$50.00   Sure grip clutch kit
$45.00   kickdown cable style bracket
$45.00   BB throttle cable
$40.00   T-bar tool
$36.00   R/T Nameplate Emblem — Grille (1970-71 E-Body)
$35.00   Master cylinder adapter
$35.00   lwr cntrl arm pivot tool
$35.00   lwr cntrl arm bushing tool
$30.00   C body washer bottle
$30.00   B/E ball joint socket
$30.00   Hood Pin and Cable Kit
$30.00   “440 6-bbl” Hood Decal
$30.00   Upper ball joint seperator
$25.00   Fender Cover, Direct Connection, White on Black
$25.00   t-bar adjuster
$25.00   J bolt for gas tank straps
$25.00   8.75 rear thrust washer kit
$24.00   BB chrome dist hold down
$15.00   battery hold down strap kit 60-65 all
$20.00   Lower control arm bracing plate
$20.00   Lower control arm bracing plate, late B
$20.00   Miller Racing banner
$20.00   Winston racing banner
$20.00   67 GTX back up lenses
$15.00   Standing RR w/ helmet decal
$20.00   big block throttle return set for tall linkage set
$15.00   BB header gasket set
$14.00   transmission output seal
$12.00   5/16 fuel tank filter sock
$10.00   cam bolt assy
$10.00   coupler-steering pot rebuild package
$10.00   heater hose bracket 67-68 big block w a/c
$10.00   3/8 tank filter sock
$10.00   chrome coil bracket
$10.00   74 fender mounted turn signals
$9.00   Street Hemi Orange Engine Paint
$9.00   Red engine enamal
$7.00   SB oil filter adapter gasket kit
$5.00   spare tire hold down wing nut
$5.00   SB exhaust manifold sleeve nuts
$5.00   70-74 batt J bolt hold downs
$5.00   NOS big block throttle return set
$3.00   valve lash decal
$3.00   gasket-8-3/4 axle foam-backing plate to axle
$3.00   DC large decal
$5.00   OE ignition key blank
$5.00   OE trunk key blank
$1.00   5/16 corbin clamp
$1.00   3/8 corbin clamp
« Last Edit: September 13, 2008 - 04:58:30 PM by HP2 »
Offline Katfish
  • 70 Challenger
Re: Lots misc parts for sale
« Reply #1 on: September 13, 2008 - 03:36:21 PM »
I'm interested in the disc brake spindles, what are they off of?
« Reply #2 on: September 13, 2008 - 05:02:18 PM »
They are the later style FJM spindles from a 78 Aspen.
Comparison with drum spindle.
Offline Katfish
  • 70 Challenger
« Reply #3 on: September 13, 2008 - 08:24:08 PM »
Was hoping for the 73 up A-body type.  I'm sure someone else can use them.
Thx
