Author Topic: front frame rails what would you do?  (Read 1158 times)
Offline farmertan
« on: September 14, 2008 - 11:03:34 AM »
when i do get the car completely stripped my biggest concern is the front frame sag. i can get a texas rust free front clip from a challenger from a guy that lives near me or should i just use those slip on frame repair from auto rust technicians if so has anyone used them and can you see the repair when the car is done. also is there any major difference between chally and cuda front frame rails this front clip has inner fenders my battery area is rusted thru that would be a bonus going that route
73 340 4sp 2nd owner since 85    brett
Offline sprecks
Re: front frame rails what would you do?
« Reply #1 on: September 14, 2008 - 01:32:57 PM »
My recommendation is go with the frame rail. I went with the caps once. I am now putting in the rails. Save yourself the hassle of doing the job twice. The caps will never look right and if you're anything like me you won't be satisfied.  :2cents:
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
Offline 72bluNblu
« Reply #2 on: September 14, 2008 - 02:37:43 PM »
While its difficult to tell from one fuzzy pic, I'm not sure that you need a whole rail. My car's drivers front rail is a bit "soft" under the battery area as well, but sound elsewhere, so I'm just going to media blast it and weld in a patch. How correct you want to be with that is up to you, you can either cut a section out of the frame and weld in the patch flush, or just weld the patch over the top (kinda like a cap) if you're not worried about it appearing stock. Some surface rust is no big deal, all these old cars have that, just be concerned about holes or major pitting. I used to do a lot of patch work when I was in Austin Healey restoration, lots of thin metal and rocker rust on those, and the patches can be very well executed if you take your time making the pattern. Also, replacing any whole rail is pretty time consuming, as you will have to do a lot of measuring to make sure that your suspension ends up in the right place. Driving a crooked car is no fun, and even if you set it all up right sometimes things move with the heat of welding. Not too likely with all the spot welds on these cars, but I'm sure its happened.
