Author Topic: Useable flywheel?  (Read 11058 times)
sleepychallenger
Re: Useable flywheel?
« Reply #30 on: September 19, 2008 - 07:27:15 AM »
found this on transamcuda.com
                                                 part#      casting #
Flywheel: 130 Teeth 10 1/2" Clutch  2264597 2264598
so does this mean that it would be correct for a T/A or AAR?
Offline hemiken
« Reply #31 on: September 19, 2008 - 07:44:48 AM »
                                                 part#      casting #
Ca-Ching Ca-Ching :poopoke: :smilielol: :roflsmiley: I can see a reposting coming on :rofl:
sleepychallenger
« Reply #32 on: September 19, 2008 - 07:48:14 AM »
im not gonna charge anymore than what i paid for it. doesnt matter if its a hemi part or a /6 part to me. part is a part and we are family, well, i might charge my actual family more  :smilielol:
« Reply #33 on: September 19, 2008 - 08:13:20 AM »
Drew, I would feel better if you just sprung for a new flywheel. It is a very important piece and needs to be in very good condition. I have learned this from experience. If it has been turned a few times, it is getting thinner and thinner with each cut. Which can cause heat cracks to happen more quickly. Vinb is going through this right now as well
sleepychallenger
« Reply #34 on: September 19, 2008 - 08:21:40 AM »
i know, im just looking at the cost of the parts. thought i could save a couple bucks either here or on the bell housing, but its not working out too well. let me know if anyone can use what i have and they can have it for the price of shipping only if you are going to use it on your car though.
Alan, vinb, and shelbydogg have first dibbs on it since they said they could use it.
« Last Edit: September 19, 2008 - 10:15:39 AM by sleepychallenger »
sleepychallenger
« Reply #35 on: September 19, 2008 - 08:24:58 AM »
Our brand new heavy-duty billet flywheels are fully CNC machined from high quality 1045 super hard billet steel. The ring gear is made from high manganese carbon steel for accuracy and superior wear resistance.
Ring gear is 130 tooth, weight is 27 pounds, and the overall diameter is 13.19 inches. The diameter of the machined face (without the ring gear) is about 12.5 inches. These fit a standard six bolt crank flange. The larger of the two bolt patterns measures 11 5/8" across (bolt hole center to center) and has 6 bolts evenly spaced around the outside of the wheel. These are setup for internal (zero) balance, (no external weights.) These are very similar to the Mopar Performance part# P4529142. Fits ALL Mopar V8 engines (even small blocks!)
Part No: 113-1014 - Billet Flywheel - NEW - Price:$ 99.95!!
is this what i need?
« Reply #36 on: September 19, 2008 - 10:32:18 AM »
sounds right to me
Offline ShelbyDogg
« Reply #37 on: September 19, 2008 - 11:39:45 AM »
The only way to tell is to have a machine shop with a balancer tell you how much it is off-balance. Any flywheel can be balance for any engine.
Offline vinb
« Reply #38 on: September 19, 2008 - 07:54:46 PM »
Hi sleepychallenger,
I'm going to pass on that one. Just want to find the correct one in good shape.
E-Town is having a swap meet next week , maybe I'll get lucky..
Thanks Vin....
sleepychallenger
« Reply #39 on: September 20, 2008 - 11:53:56 AM »
Thanks Vin....
its all good. no hurry to get rid of it yet. just erked that i have it.
sleepychallenger
« Reply #40 on: September 20, 2008 - 06:56:12 PM »
ok guys, since nobody stepped up, i know short time to jump up, i am going to put it in the parts for sale section, any idea on what a fair price for this thing is? maybe something like 35-40 + shipping?
« Reply #41 on: September 21, 2008 - 01:34:40 AM »
if we knew what it was balanced for it could be very valuable , I would say $50 minimum is more then fair + shipping
sleepychallenger
« Reply #42 on: September 21, 2008 - 10:36:38 AM »
so should i get my buddy to take it somewhere to check the balance? if we know the balance numbers, could we tell what it is for?
« Reply #43 on: September 21, 2008 - 11:35:53 AM »
couldn`t hurt
Offline ShelbyDogg
« Reply #44 on: September 21, 2008 - 07:31:17 PM »
That's what I said also. You will have to find out what the off-balance is for before you can sell it anyway.
