Author Topic: iowa barn 73 challenger  (Read 3313 times)
Offline hamicr
« on: September 16, 2008 - 04:13:22 AM »
here we go you all know i just got this sweet beast from a barn in iowa. now it's time to do the fixing. here is the plan keeping as true as i can.  :screwy:
there are not many left that have not been swaped or souped up.  :violin: so i going to stick to the build sheet i found in the car look a pic. and i hope a can show you all how well it gose or get help when i'm  :banghead: and :stirpot: on ideas. so here are the starter pics will get more as i go. wish me all the luck.
Offline Super Blue 72
    • Phil's Super Blue '72
Re: iowa barn 73 challenger
« Reply #1 on: September 16, 2008 - 04:25:17 AM »
Looks pretty cool!  :thumbsup:  I like the Keystone Klassic rims!  I have a set too!
sleepychallenger
« Reply #2 on: September 16, 2008 - 05:53:03 AM »
good luck looks like a good time  :2thumbs:
Offline 70shaker6pk
« Reply #3 on: September 16, 2008 - 09:31:12 AM »
Looks like a very nice car to start with,,, keep those pic's coming.
'JS23V0B'  1970 Challenger R/T N96 440 Six Pack
Offline HemiChallenger
    • E-Body Boyz
« Reply #4 on: September 17, 2008 - 01:46:18 AM »
If your going stock and dont want those rims and tires i will buy them off of you. Let me know :thumbsup:
Looks like a nice project you got there  :worshippy
WANTED: 1970 Original FJ6 Sassy Grass Road Runner, Original FJ6 Cars Only
Offline hamicr
« Reply #5 on: September 22, 2008 - 03:19:38 AM »
 I was :working:this weekend as i just got more parts in, carpet, more trim. real nice stuff. and lets not for get the seats covers too. being  :useless:hear is some for your  :popcorn: had a good time doing it too.
« Last Edit: September 22, 2008 - 03:38:54 AM by hamicr »
Offline hamicr
« Reply #6 on: September 22, 2008 - 03:54:37 AM »
more work done over the weekend while i  was:working: i looked closer at the top and the pics from grasshopers rebuild post lead me to  :thinkerg: that some one has been under the top. its off set to the outer edge not good. so off it came, :poopoke: and not sure how to head from here.  :1zhelp: best bet is to pull windows, but i have never done one any hints out thier.
« Last Edit: September 22, 2008 - 03:59:12 AM by hamicr »
Offline go-fish
« Reply #7 on: September 22, 2008 - 08:39:33 AM »
Wow. You are doing good work. I love the blue interior
Offline go-fish
« Reply #8 on: September 22, 2008 - 08:43:48 AM »
Wat was the original color? It looks like Gun Metal Grey under the top.
Offline ambitions2
  • ..we gunna make it to the finish line...
    • 72 Challenger EV-2 Project
« Reply #9 on: September 22, 2008 - 10:53:32 AM »
What I would do:
1) Remove the trim - carefully, I had the tool
2) Pull the glass front and back
   - You can do this (I did it my first time), but make sure you take your time and are paying close attention.  I first took a putty scrapper and scrapper along the weather stripping to get as much off as possible.  You don't have to apply any pressure, just make sure the edge of the scrapper is sharp.  After you remove what you can, I examined the windshield and found a spot where I could feed my wire (I used a cheese wire cutter) through and then tied it to a handle.  Slowly worked my way around.
Project: 1972 Challenger - 340 AT 8 3/4 3.23 gears
http://community.webshots.com/user/jtitan2220
Offline hamicr
« Reply #10 on: September 23, 2008 - 02:29:33 AM »
frist thanks for the coment on the blue inter . as for the top it looks more like a baby bule but some one has been under the top before, the rear piler has been redone and they filled it full it is clear out to the body line. going to have to fix that.
Offline hamicr
« Reply #11 on: September 23, 2008 - 02:31:01 AM »
ambitions2  thank you for your input i did get the trim off ok but now need to try your way so thanks again
Offline hamicr
« Reply #12 on: October 01, 2008 - 02:15:16 AM »
What I would do:
:ylsuper: :working:worked great you mite need to add a box of gloves and remove any thing you don't wish to get drity because you will get drity doing this job. thank you and will adding the new pics soon. i will have to edit them for the net now that the car is naked...... :smilielol:
Offline hamicr
« Reply #13 on: October 03, 2008 - 04:24:20 AM »
 :swear:after the fun time of removing the winsheild and back window. did not see any point in not puting a coat of paint on it. of course i would not do just that it is all going to bear it all after the two hours of sanding and find the car should have  :wave:on the way by. but it is all for its own good. so here are the lates. and if you have a hard time with nakedness on here you better not look.
Offline hamicr
« Reply #14 on: October 25, 2008 - 12:12:45 AM »
this is the late's up date for you challenger lovers out there.
after weeks of sanding and cut out old pacths and puting on real parts here it is in its new blanket of gray. hoping the weather will warm up a bit so i can paint it its true color tell then i'm going to work it over and over tell there is no mistakes any where lol
