Author Topic: Steering column connectors  (Read 1329 times)
Offline MrMopar440
« on: September 16, 2008 - 06:24:53 AM »
I have a Painless generic harness in the car. The Safety inspection busted me for not having an original comumn installed, so it is back in. My question is: What kind of connectors do you use to hook up the ignition and turn signal harnesses? I can do a permanent splice, but would rather have something that can be disconnected for component replacement. I do not have the car-harness ends for these. Thanks
Offline Roppa440
Re: Steering column connectors
« Reply #1 on: September 16, 2008 - 08:23:08 AM »
You have to re-use the original connectors by removing the pins, cleaning them up, soldering them onto the new wires, and re-inserting them into the plastic blocks.
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
« Reply #2 on: September 16, 2008 - 11:21:19 AM »
Painless uses the GM connectors I believe , you can go to the wreckers & get a set of matched plugs out of virtually anything & solder your wires onto the male & female plugs , just leave 4" to solder to on both sides of the plugs , GM plugs for the ign switch will not work as they plug straight into the ign switch so no male end , the other solution is to use one of the small 7 pin trailer plugs
Offline MrMopar440
« Reply #3 on: September 17, 2008 - 03:32:31 AM »
Thanks Chryco - I hadn't thought enough "out of the box" on this one. Those trailer connectors - or something like that should work just right. I bought the generic harness with no connectors.
Roppa440 - No original connectors
« Reply #4 on: September 17, 2008 - 03:34:58 AM »
 :2thumbs:
