Author Topic: final streach  (Read 3489 times)
sleepychallenger
final streach
« on: September 16, 2008 - 11:20:39 AM »
i figured that i would throw this out there
 :bigsmile:
10.5" bellhousing
shifter mount plate
Clutch switch start wire harness
correct speedo gear (383 323 gears)
hardware
new rear tailshaft seal
pilot bearing
tranny to bell housing bolts
bell housing to engine
shift plate bolts
shifter to shift plate bolts
shifter boot and trim ring
shift rod tabs
Re: final streach
« Reply #1 on: September 16, 2008 - 12:44:03 PM »
I got a new tail shaft seal plus some others for your trans , and a crank bushing here. probably most of the bolts too. Your automatic trans bell bolts will work Drew.
sleepychallenger
Re: final streach
« Reply #2 on: September 16, 2008 - 12:59:07 PM »
woo hoo. Alan, you da man. Im gonna definately bring you a cookie  :bigsmile:
10.5" bellhousing
shifter mount plate
hardware (clips)
pilot bearing
shift plate bolts
shift rod tabs
i think with Alan having the strike thru stuff, that is what i should be left with needing.
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: final streach
« Reply #3 on: September 16, 2008 - 01:13:11 PM »
Does your speedo work correctly right now?  If so, you should be able to use the gear in your auto.
sleepychallenger
Re: final streach
« Reply #4 on: September 16, 2008 - 01:15:59 PM »
yup, works great.  :2thumbs: i didnt know if they were interchangable or not.
Offline Jacksboys
Re: final streach
« Reply #5 on: September 16, 2008 - 01:32:11 PM »
I know I used one out of a 4-speed in my 904, so it should work, just make sure you install it on the correct tab.
Re: final streach
« Reply #6 on: September 16, 2008 - 06:01:58 PM »
LOL  There may be the right one in the trans now. And there is no shifter mount, I looked
sleepychallenger
Re: final streach
« Reply #7 on: September 16, 2008 - 06:43:46 PM »
 :walkaway:
Offline cudaguy71
Re: final streach
« Reply #8 on: September 17, 2008 - 05:28:33 PM »
I have the following:
shifter mount plate
shift plate bolts
Eddie
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
2003 Dodge Dakota Sport
1979 Plymouth Arrow
sleepychallenger
Re: final streach
« Reply #9 on: September 18, 2008 - 12:39:05 AM »
shifter mount plate
shift plate bolts
Eddie
pm sent
sleepychallenger
Re: final streach
« Reply #10 on: September 18, 2008 - 11:30:02 PM »
10.5" bellhousing
hardware (clips) (just bought shift rod clips on ebay) are there any others that i will need?
tranny to bell housing bolts (can these be bought at the local parts store? I just cant see paying $16 for bolts being shipped if i can buy them when i get back. )
shift rod tabs
Update 10/3
« Last Edit: October 03, 2008 - 07:24:38 AM by sleepychallenger »
sleepychallenger
Re: final streach
« Reply #11 on: October 02, 2008 - 11:23:54 PM »
bump
sleepychallenger
Re: final streach
« Reply #12 on: October 25, 2008 - 10:08:42 AM »
ok guys, looks like i have everything but the shifter mount pad. the one i got was for a b body. anyone got one, i need it pretty quick. help a brotha out please.
Re: final streach
« Reply #13 on: October 25, 2008 - 10:10:11 AM »
Did you pm Dave at roseville parts?
Offline 73Chally
Re: final streach
« Reply #14 on: October 25, 2008 - 10:22:40 AM »
I got mine through Brewer last year.  I think the price is up $10 from when I bought it, though.
http://www.brewersperformance.com/proddetail.asp?prod=SMP316
