Author Topic: Driveshaft question  (Read 1108 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Driveshaft question
« on: September 16, 2008 - 01:06:07 PM »
Is a 340 4 speed Challenger driveshaft the same as a 340 727 automatic Challenger driveshaft?
1996 Dodge Viper GTS Coupe
Re: Driveshaft question
« Reply #1 on: September 16, 2008 - 01:08:49 PM »
If they both came with an 8 3/4 yes
Offline 72hemi
« Reply #2 on: September 16, 2008 - 01:14:35 PM »
Yep, both 8 3/4 rears, thanks.
Offline black71
  • eph 6:12
« Reply #3 on: September 16, 2008 - 08:14:24 PM »
so what if i have a driveshaft fom an auto small block and am goin to an auto RB, wil it work?
Offline 422STROKER
  • Member Since 6/3/06
« Reply #4 on: September 16, 2008 - 08:19:00 PM »
If the SB has a 727 yes.
Tom
Tom
Offline black71
  • eph 6:12
« Reply #5 on: September 17, 2008 - 08:13:40 PM »
schweet! so if i may ask...whats the deal with u-joints? different sizes and what not...will the ones already fitted hold up fine to my 440? if not what are my options for upgrades....i understand that they held up from the factory i guess i'm just askin if small and big blocks used the same size
Offline 422STROKER
« Reply #6 on: September 17, 2008 - 09:54:36 PM »
Should be a 7290 joint but could be a 7260, go for the non-greasable u-joints for strength.
Tom
Tom
« Reply #7 on: September 18, 2008 - 01:19:05 AM »
I would recommend the 7290 joint which is 2 5/8 " across inside the ears
 the other size is the smaller 7260 joint which is 2 1/8"
Offline black71
  • eph 6:12
« Reply #8 on: September 18, 2008 - 10:24:52 PM »
k, will the 7290 work with my existing set up?
Offline 422STROKER
« Reply #9 on: September 19, 2008 - 04:41:26 PM »
You'll have to check what you got for a rear end size.  If you find it is the 7260 then you can get the conversion joint to mate to it and keep the 7290 everywhere else.
Tom
Tom
