Author Topic: 71 Challenger disc brake anti-rattle clips  (Read 4962 times)
Offline mrob
« on: September 18, 2008 - 10:28:16 AM »
Hi,
Does anyone have pics or a link to some pics (or a diagram) of the anti-rattle clips on 71 Challenger disc brakes? I'm getting ready to rebuild the front calipers on my R/T and ordered caliper hardware kits which included some clips, pins, rubber bushings.
I'm pretty sure I can figure out how to install the clips except for some that look like zinc-plated, "bent wire". Those "wire" clips are not on my car, so I'm not sure how to install them.
Any help is appreciated.
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: 71 Challenger disc brake anti-rattle clips
« Reply #1 on: September 18, 2008 - 10:46:45 AM »
This should help.
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
Offline mrob
« Reply #2 on: September 18, 2008 - 01:04:17 PM »
 :thumbsup:
Thank you purple1 !!  Judging by the pics, you must have been through this yourself.
Offline autoxcuda
    • Spring Fling
« Reply #3 on: September 18, 2008 - 11:50:13 PM »
I think Bill Rolik repros the clips and the correct 3/8 hex caliper pins and the correct plating. IIRC, brenterprises on ebay
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
Offline mrob
« Reply #4 on: September 19, 2008 - 03:26:49 PM »
Autoxcuda - thanks for the tip. I already have the clips, but I'll check it out on ebay anyway.
Offline wally426ci
    • maryland mopars
« Reply #5 on: September 20, 2008 - 08:22:55 AM »
 :popcorn:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Changin Gears
« Reply #6 on: September 20, 2008 - 08:26:00 AM »
I always just leave the anti-rattle stuff off - never actually heard any rattling.
Offline Finoke
« Reply #7 on: September 20, 2008 - 08:57:26 AM »
I heard the same thing. That if you toss them you won't notice a difference. Unless your looking for factory correct. THen I would keep em.
Offline purple1
« Reply #8 on: September 20, 2008 - 09:27:02 AM »
:thumbsup:
You are quite welcome. I went though this last year and I only wanted to do this job once.
 While :iagree: The anti-rattle springs can be left off. The only thing they seem to do is help hold the pad on the caliper as you assemble the brakes. You should not skip the pin positioners, as they help hold the inner bushings in place. And that would cause a rattle if they popped out. :nono:
Dave :wave:
« Last Edit: September 20, 2008 - 09:35:54 AM by purple1 »
Offline poolboy
  • 1970 R/T 440 4 speed dana 60 3:54
« Reply #9 on: September 23, 2008 - 08:57:14 PM »
Hi, I was reading your posts and I am currently rebuilding my brake calipers and I am looking for new bushings ( inner and outer) anyone know who makes these? Thanks
1970 Challenger R/T
1970 Challenger R/T
1999 Durango -the wife's
2009 Scion xD-daughter's
2003 Dakota Quad Cab-son's
2003 BMW 325i-mine
Offline LAA66
« Reply #10 on: January 19, 2009 - 09:58:55 PM »
 Bump.
 I'm there now also. Who makes these replacement parts?  Mine are 9/16" hex head pins with the plated finish. Thanks.
« Reply #11 on: January 20, 2009 - 01:43:09 AM »
sounds like Bill Rolik has them
 if you are replacing the calipers anyway order them semi loaded & they include all the parts
