Author Topic: Gear oil and anti slip preferences?  (Read 914 times)
Offline torredcuda
  • Epping NH joined 11/23/03
« on: September 20, 2008 - 07:14:00 AM »
Going to change the gear oil to see if it helps my s/g work better as it`s not been locking up and spinning both tires since putting on the drag radials.Any gear oil and additive better than others?Should I get the Mopar additive or just the local parts store brand?
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Changin Gears
Re: Gear oil and anti slip preferences?
« Reply #1 on: September 20, 2008 - 08:36:09 AM »
I wouldn't bother changing it unless it currently have synthetic in it now, it sound just worn out.
I used both the Chrysler and KW (from Autozone) additive with success.
Offline Supercuda
« Reply #2 on: September 20, 2008 - 07:40:38 PM »
My experience with limited slip additives has been that they are all pretty good. The GM, MOPAR, and other, branded additives are all excellent; you will pay a premium for the name. I use the additive that meets the required specification for the diff I am playing with. If it is cheap, that much the better. Gear oil is a matter of personal preference, but you will get better quality with a name-brand oil, in most cases. Sometimes, the "store brand" is a re-labeled premium brand, so look carefully at labeling. For instance, NAPA's store brand oils are made by Valvoline's producer, Ashland Oil. I use an 85W140 weight oil in my differential, and would recommend a thick lubricant for any abusive environment, like racing, or off-road play. It does sound as if you probably have a sick unit on your hands, and may be in need of new clutches, or a new carrier. Look for a lot of metal in the removed fluid- that would be a bad sign. If the issue is an incorrect fluid, or the lack of the proper additive, then there is usually a "ratcheting" sound associated with the lack of limited-slip operation. If it is quiet, and doesn't function normally, the chances are that it is time to tear it down.
Offline torredcuda
« Reply #3 on: September 21, 2008 - 07:14:34 AM »
I know the s/g is most likely worn out but figured it`s worth a shot to give it fresh fluid and nurse it till the end of the season.
Jeff
