Author Topic: Steering Box  (Read 799 times)
Offline imean340
Steering Box
« on: September 20, 2008 - 11:58:04 AM »
Hey, can anyone point me in the direction of a cheap power steering box (remaned or otherwise) for a 70 challenger? Is the steering box the same on the 70 vs 71-4? Thanks!
Edit: I should add that I don't really need anything fancy, high ratio or stiffer feeling. Just a stock replacement would do (the car is a cruiser/drag car...it's not seeing any fast turns with the skinnies up front anyway lol). Just need something decent for a good price.
« Last Edit: September 20, 2008 - 12:08:33 PM by imean340 »
Kris
'70 340 challenger- 69 crank and block,  bored .030 over, speed pro forged pistons, eagle forged I beam rods, 2.02/1.60 "J" heads, 3 angle valve job, 230*/230* .480/.480 110LSA cam, Eddy performer manifold, hooker supercomp 1 3/4's headers, Holley 670 street avenger, TACTRANS 727, Protorque converter, 4.56 gears, L60 M/T "I" treads, SS springs, 70/30+50/50 drag shocks---spray coming soon---
Offline 422STROKER
  • Member Since 6/3/06
Re: Steering Box
« Reply #1 on: September 20, 2008 - 12:43:02 PM »
I got mine from Autozone for a 73 along with a 73 pitman arm, bolted in.  The early pitman arms are much more money and the boxes are too.  IIRC after the core charges were clear it was 170 buck for both.
Tom
Tom
Offline BB73Challenger
Re: Steering Box
« Reply #2 on: September 20, 2008 - 05:59:53 PM »
When I still had power steering that's what I did - the pump was good, and dodged that expensive pitman arm.
Autozone had it in next day.
Jeff from Cleveland, Ohio
Offline imean340
Re: Steering Box
« Reply #3 on: September 20, 2008 - 08:13:58 PM »
Cool, thanks. so im guessing the only difference is in the pitman arm shaft/splines, no length/size difference on the pitman arm overall or the steering box? Don't want to put a steering box in that doesn't fit my headers or a pitman arm in that throws my alignment off, assuming neither will be changed if you guys have done it.
thanks again!
Kris
Offline 422STROKER
Re: Steering Box
« Reply #4 on: September 20, 2008 - 08:18:57 PM »
Should be good, i had no problems with mine.  I did have it aligned afterwards due to some minor suspension work i did though.
Yes the sector shaft is a different size but they bolt up/in no problem.
Tom
May as well rebuild the coupler while you're in there too.
Tom
Offline LAA66
Re: Steering Box
« Reply #5 on: September 21, 2008 - 12:26:08 AM »
 Just replaced a 70-71 box and pitman arm for a Firm Feel 72 up. No differance in the arm besides the shaft diameter.
