Here's an update for those who care:
The new TS arrived in the mail last week so I changed it out this past Sunday. Had to trim the flasher knob, as expected, and also noticed the old one was "modified" in the same way. OK, someone's played this game here before...
Anyway, before reinstalling the steering wheel I decided to hook the battery up & test it out. Left turn signal? Check. Right turn signal? Check. Flashers? Pfzzzt! - Did I just see a wisp of smoke come out of that new flasher switch!?
Come to find out that I blew two fuses: flashers and brake lights. I replaced the fuses and decided to double-check to see if the new switch was wired correctly (luckily I still had the old one next to me). The wiring checked out fine, so I decided to test things out again, step by step, to try to figure out where the problem might be. To my amazement, everything worked fine!
Well, that was short-lived. I took the car out for a spin (after putting the steering wheel back on, of course), and one block from my house I applied the brakes while pulling up to a stop sign. As I did so, the radio momentarily went dead, and then was fine again. I knew at that moment I had blown another fuse, and sure enough, the brake lights again! I put another fuse in (I have stock in Buss 20-Amp fuses, don't you know!
), and proceeded to recheck everything. This time, all is well again, including with the engine on or off, the lights on or off, and the radio on or off. At this point I switched her off and put the car cover back on.
OK, I understand that fuses exist to protect the wiring, and blow if you have a short. My next step is to go over the brake light harness with a fine-toothed comb, but I guess this is to be expected with a 40-yr-old electrical system (and I know enough to carry extra fuses
). I'm wondering if anyone out there has had any similar problems, and if so what was the cause? Believe it or not I'm actually pretty good at electrical trouble-shooting & repairs, but it might help me out to hear from anyone who's had similar problems.
Thanks,
