Author Topic: Value of BS vs. BH and Clone  (Read 9606 times)
Offline LeakyGasket
« on: September 21, 2008 - 10:12:03 AM »
I want to take a 318 BH23 car and change out the drivetrain to accommodate a 426 engine.  Is there any difference in value, if all other things are "sort of" equal, of starting with a BS ('Cuda) car versus a BH (Barracuda) car?  In the end, would the BS car be worth more, or is it just about a wash?
Offline moparmussel
Re: Value of BS vs. BH and Clone
« Reply #1 on: September 21, 2008 - 10:46:20 AM »
once you change the car from numbers matching the value ends up being how much someone will pay for your creation.you now have limited the broad range of collectors to someone with the same taste as you to buy.at this point of change the options on the car will help increase the value,disc brakes,sway bars etc.if the car is all there i would restore all stock,get the big bucks and then buy a mismatch car to create a monster!
74 cuda,az car. built 383,727 manual shift,reverse pattern.8th cuda project,cant get enough!
« Reply #2 on: September 21, 2008 - 10:48:45 AM »
You don't mention the year of the car, but the BS would be worth a little more if all else is equal. Given that 318's don't get much respect in the value department you would be increasing the value of the car by putting in a Hemi drive train in my opinion.   :2cents:
Offline cudadave72
  • you motorboatin sob!!!
« Reply #3 on: September 21, 2008 - 10:49:34 AM »
I feel a BS car will always be worth more than a BH car no matter what you do to it, both cars being equal that is. BS cars are worth more to start off with and regardless of the drivetrain the base car will always have more valve.
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline plumcrazy704406
« Reply #4 on: September 21, 2008 - 05:41:52 PM »
are you cloning something for yourself or to flip? If your building for yourself, with the hopes of never selling than I don't think it matters. Buy the best starter car you can. Metal cost $$$. If you do the changeover correctly you should have a great ride. Would it matter to me as a buyer? I don't think so, as long as the car is done correctly. remember it's no longer a #'s thing. If your biggest concern is the best bang $$ for the $$, then I wouldn't be doing anything other than a resto on the BS car as it was and probably $ for $ (altough $ figures would be lower in retrospective) you would end up ahead if you look at the % of profit. jmo and yes I may be crazy!
 :bigsmile:
This thought may not be politically correct, but is an opinion offered. It may be correct? or it may be wrong? It is not designed to appease those needing shelter from the real world.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #5 on: September 21, 2008 - 06:11:35 PM »
Once you modify or clone it there would maybe a very slight difference as someone could always restore a BS car and keep it`s value where as a BH car wouldn`t be worth anymore restored than modified-maybe less.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline LeakyGasket
« Reply #6 on: September 21, 2008 - 06:47:26 PM »
I am building for myself and own pleasure, but want to retain as much value as possible.  From reading the responses, it looks like a better start would be the BS 318.  I would probably never clone anything else, like 340 or 383, if it had a lot of #s matching stuff, unless I kept all the other stuff.
Offline 360 'CUDA
« Reply #7 on: September 21, 2008 - 06:55:31 PM »
The real advantage on starting with a BS 318 car is you get all the fun parts like the 'CUDA only chrome and trim like the double bump hood and rear valance as well as the swaybars.
You wont find any 318 '70 or '71 'CUDAs though. That didn't start that until '72 so only cars with round tail lights could be BS 318 cars
« Last Edit: September 21, 2008 - 06:57:06 PM by 360cuda »
Offline black71
  • eph 6:12
« Reply #8 on: September 21, 2008 - 07:38:33 PM »
i would say that no matter the year a real 'cuda is worht more than an equivilant barracuda. i know if i was looking to buy a real bs would be worth more to me  :2cents:
Offline cudadave72
« Reply #9 on: September 21, 2008 - 08:54:18 PM »
Offline hotrod98
    • Maniac Musclecars
« Reply #10 on: September 21, 2008 - 10:15:38 PM »
Do you already have the car that you plan to use? If so, the BS, BH thing isn't important. If you install a 426 into anything, it can be removed at any point. Just keep the original components to re-install later on. By the time you're finished, you will spend 20 grand installing a 426 into just about anything. That crate motor is missing a lot of stuff. Remember that you will need to change out the rear if it's smaller than a 3/4. That 20 grand you spend will make that car worth about 20 grand more. Been there...done that.
I'm assuming that you have either a 73 or 74 since you're talking about BS 318's.
The 426 will make the 70 and 71 BS cars worth even more since they're the only two years that a 426 would have been available .
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline Carlwalski
« Reply #11 on: September 21, 2008 - 11:18:22 PM »
When I was looking for a 'Cuda for my custom build (clone is such a bad word and in many cases incorrect  ;D ) I searched for a BS23 car only. Not sure why when I actually thought about it though lol. Same shape, rolling chassis, custom build anyway so why bother? Guess for me it was peace of mind knowing I had my Triple Black 1971 Plymouth 'Cuda. A Triple Black 1971 Plymouth Barracuda just doesn't sound or look as cool, to me. Little items as well contributed to my selection and when I was searching BS cars vs. BH in terms of cost were very obvious with BS cars going for $5-10K more depending. Remember these were only project cars (rolling chassis in some cases).
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline LeakyGasket
« Reply #12 on: September 22, 2008 - 07:15:16 AM »
No, I don't have the car yet, and I'm looking for a 71.  I'm kinda ignorant and trying to learn, and didn't realize that you couldn't get a 70 or 71 in 318.  I thought I saw some sales out there indicating as such, but not so I guess.  That probably means 340 is my only choice (maybe 383?) since anything else either doesn't exist or is way past my means.  Looks like I may have a bit of a problem here -- my brain is set in concrete on a 71 BS23.  The fender tag must say BS.
There's a guy in Texas with a nice BH body that I was all keen on until I locked in on 'Cuda.  Darn brain.  It's all fun though.
Offline Carlwalski
« Reply #13 on: September 22, 2008 - 09:09:07 AM »
Nothing wrong with that mate, I was exactly the same with my 71. Well worth it, I love my 'CUDA :2thumbs:
Offline LeakyGasket
« Reply #14 on: September 22, 2008 - 10:26:31 AM »
And may I say, beautiful car.  Is that B5?  My first choice is B5, followed by B2.
