Author Topic: 315s  (Read 1167 times)
Offline Justins72
315s
« on: September 21, 2008 - 01:11:32 PM »
i came up on some pretty much brand new 315/30 18s michalines for free and was wondering if they will fit on a 18X10 rim? Its just a crusing/show car so there wont be any really hard turn taking.  thanks
Re: 315s
« Reply #1 on: September 21, 2008 - 01:14:29 PM »
a 315 width tire ona 10" wide rim seems to be in the correct range
Offline Justins72
Re: 315s
« Reply #2 on: September 21, 2008 - 01:18:46 PM »
Thanks Chryco thats what i like to hear. Cant wait to put these bad boys on.
Re: 315s
« Reply #3 on: September 21, 2008 - 01:31:36 PM »
all you need to do is go to a tire site & look up that size tire & it will give recommended rim width for the tire
Re: 315s
« Reply #4 on: September 21, 2008 - 02:22:41 PM »
My question is... Are you putting this on an E-Body?  I would think you would need some modifications to do so.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: 315s
« Reply #5 on: September 21, 2008 - 02:31:24 PM »
A 315 series tire is 12.4 inches wide. 315 is the width in millimeters. the conversion from millimeters to inches is divide by 25.4. I think with an 18 you will need a 12 or 13 inch wide rim, because with that small amount of sidewall I don't think have a tire that is 2.4 inches wider than the rim is a good idea.
« Last Edit: September 21, 2008 - 02:35:22 PM by 72hemi »
1996 Dodge Viper GTS Coupe
Offline GoodysGotaCuda
Re: 315s
« Reply #6 on: September 21, 2008 - 03:19:01 PM »
You'll definitely need some modifications to get it on a stock car
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: 315s
« Reply #7 on: September 21, 2008 - 03:35:09 PM »
That's still workable. It is only 1-1.25 per side that the tire will bulge, which is pretty close to ideal.
Fitting a 10" rim under the car isn't going to happen without some mods, however. Simple answer, jack it to the sky with high lift springs. Correct answer is to relocate the springs 3/4" in and use a B body rear housing.
Offline Justins72
Re: 315s
« Reply #8 on: September 21, 2008 - 03:46:57 PM »
i already have 18X10s in the back with a 285/35 18 with out moving the springs and still have quit a bit of room on either side. Now i dont know if the person before has put a different rear in the back or already moved the springs inward.
Re: 315s
« Reply #9 on: September 21, 2008 - 05:34:13 PM »
Probably the fact it is such a short tire i guess. I have 295s on a stock setup, but I run 28.5" tall tire. Your 315s are a full three inches shorter than my rear tires.
1976 Dodge Warlock
Re: 315s
« Reply #10 on: September 22, 2008 - 03:32:13 AM »
the 315s I looked up online listed 10" as minimum rim width
