Author Topic: pedal travel  (Read 1228 times)
sleepychallenger
pedal travel
« on: September 21, 2008 - 05:37:46 PM »
Ok, im not home but my buddy is hooking my car back up trying to get it atleas mobile before i get back. I had this problem after putting the eddy carb on and now he is having the same trouble. there isnt a whole lot of pedal travel and when the pedal is on the floor the carb is only open 1/4 of the way. any ideas fellers? ???  :feedback:
Offline Supercuda
Re: pedal travel
« Reply #1 on: September 21, 2008 - 07:51:26 PM »
At the very least, the cable needs to be adjusted. There should also be a lot of "dead" travel in the pedal, where no movement at all happens. I have also seen the cable incorrectly attached to the throttle arm, causing a severely shortened arc of travel. Investigate these possibilities first.
sleepychallenger
Re: pedal travel
« Reply #2 on: September 21, 2008 - 08:12:21 PM »
We have tried adjusting the cable, but not quite sure how other than up on the manifold. at full throttle, the butterflies should be more than 1/4 open.
Offline Aracer
Re: pedal travel
« Reply #3 on: September 22, 2008 - 12:33:48 AM »
Pull the cable sheath all the way back till there is a only a slight droop on the cable attachment (choke off), then re tighten the nut on the cable sheath.
The peddle normally comes up when the slack is removed.  You may also need a kit from Eddelbrock for the Mopar application.
Re: pedal travel
« Reply #4 on: September 22, 2008 - 03:44:01 AM »
there is a braket that bolts to the eddy carbs for Mopar applications , you need to have the pin closer to the throttle shaft to gain more advantage pedal travel to carb travel
sleepychallenger
Re: pedal travel
« Reply #5 on: September 22, 2008 - 10:08:53 AM »
do you know what the eddy part number is?
sleepychallenger
Re: pedal travel
« Reply #6 on: September 22, 2008 - 10:21:46 AM »
Chrysler and Ford Throttle Lever Adapters
Throttle Lever Adapter #1481 fits 1966 and later Chryslers. #1483 is for Ford automatic transmission equipped vehicles with cable operated throttle (except A.O.D.). Both accept cruise control. Use with appropriate throttle cable plate when necessary. Available in gold iridited finish to match Edelbrock Performer Series Carbs or black to match Edelbrock Thunder Series AVS Carbs.
RPM Dual-Quad Kit for Small-Block Chevy Gold Finish Black Finish
Chrysler Throttle Lever Adapter (1966 and later) #1481* #1843*
i take it is this one
Re: pedal travel
« Reply #7 on: September 22, 2008 - 01:07:05 PM »
1481 is what I have used
sleepychallenger
Re: pedal travel
« Reply #8 on: September 22, 2008 - 01:30:08 PM »
just ordered it from summitt. hopefully this will get that part taken care of. now its back to the 4 speed parts
sleepychallenger
Re: pedal travel
« Reply #9 on: September 23, 2008 - 02:41:23 PM »
 :wow: that got there fast. I ordered that part last night and it got there today. that is awesome. he said that he put on that bracket and now i have full throttle range and everything is working as it should.  :bigsmile:
