Author Topic: Free samples, Shrink wrap  (Read 2925 times)
« on: September 21, 2008 - 05:54:20 PM »
Our company gets a lot of free samples sent to us.
Every week we get connectors, Shrink wrap tubing and connectors.
I have 2 large shrink wrap tubes about 4" long to the first person who asks for them.
Please don't ask for them if you aren't going to use them right away. Leave them for someone who does really need them. I'll get more stuff and post here if there is enough interest in wire connectors wanted.
Offline 422STROKER
  • Member Since 6/3/06
Re: Free samples, Shrink wrap
« Reply #1 on: September 21, 2008 - 07:03:02 PM »
What's the recommended wire diameter for that?  It looks like battery cable stuff?  6G or 4G?
Don't need it but it may help someone.
Tom :2thumbs:
Tom
« Reply #2 on: September 21, 2008 - 07:05:09 PM »
Should work good for 6 AWG.
« Reply #3 on: September 22, 2008 - 03:30:09 AM »
I have lots but thanks  :2thumbs:
 some wire connectors could be useful as they can be hard to locate
« Reply #4 on: September 22, 2008 - 04:09:44 PM »
I'll start looking for connectors then. Post pics and if possible, the dimensional drawing from the mfg.
« Reply #5 on: September 23, 2008 - 09:06:03 PM »
I have these today to give away.
90 degree brass terminals. Good for tight locations.
+ & - 42 Amp  rated starter clamps; small size like on the jumper boxes.
« Reply #6 on: September 25, 2008 - 07:00:40 PM »
Just found a whole bunch of these layin around. These have the translucent red shield going over them.
http://catalog.tycoelectronics.com/TE/bin/TE.Connect?C=1&M=BYPN&TCPN=2-520407-2&RQPN=2-520407-2#features
« Reply #7 on: September 26, 2008 - 12:03:34 AM »
have you ever seen the thread together  multiple use butt connectors instead of crimp single use type ?
« Reply #8 on: September 26, 2008 - 12:09:35 AM »
I'm not really clear from your description what you're describing. Is there an application or a picture?
« Reply #9 on: September 26, 2008 - 12:21:04 AM »
a friend bought a 70 Chall from LA & it had a type of butt connector with a tapered steel pin in the center & threaded end caps , , you do not need to strip the wire just insert it through the hole in the end cap & tighten it , the tapered pin pushes into the wire end & flares it so it will not pull apart & become water tight , if you need to disconnect the wire it takes seconds to unthread it & reconnect it later , just wondered who made them as them seem like a great Idea , my friend would like to get some more of them if possible
« Reply #10 on: September 26, 2008 - 12:26:25 AM »
Interesting. I copied your description and sent it to my work e-mail to look into this further. A picture would be helpful if you can get one.
« Reply #11 on: September 26, 2008 - 12:34:58 AM »
I will try to get a pic
« Reply #12 on: September 29, 2008 - 04:48:03 PM »
Better yet, could you get me a sample?
Once I locate the source, theres a good chance I may be able to get multiple samples.
