There is a specific 4 speed console bracket, but save yourself the $50 or so and just use the two screws that go into the rear tunnel bracket, which you say are fine. You might have to cut the front bracket off to eliminate any interference, but the 2 rear screws provide all the support you need. I tell you this through experience because I just put my console back in a couple weeks ago using only the rear bracket, and it is just fine with no rattles or vibration, etc.
