Author Topic: duster wiring  (Read 3771 times)
Offline mytmopar
  • 69 gtx 440 vert-71 chally 340 blown-70 R/T coronet
duster wiring
« on: April 26, 2002 - 07:02:18 PM »
??? guys i know yall are going to laugh because i know yall heard about turning on the lights and the radio coming on and putting the car in first and it going backwards, etc. well i put a ralley underdash wiring harness in my duster w/ rally dash and when i hooked up the harness in the motor well i turned the ignition on and the horn blows. funny huh! well the only thing i can think of is since the car is an original 318 car with standard dash and wiring then i need to put the right wiring harness in the motor part?  i could use some help if anybody knows how to solve the problem.  funny thing is all the lights work right from that part of the harness?  thanks mike in tn
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
get in, sit down, buckle up, and hold on! see you later, BYE!!
Re: duster wiring
« Reply #1 on: April 26, 2002 - 10:50:56 PM »
Sounds to me like there is a problem in the plug to the column  ;)
Offline mytmopar
Re: duster wiring
« Reply #2 on: April 27, 2002 - 08:12:45 PM »
thanks for the reply!  i was at the bristol drags today and talked to a guy at painless wiring and he said between the dash and engine harness there is a wire crossed. i just need to find the ignition to starter wire and switch them.  simple huh?  mike :-/
