Author Topic: t/a steering box  (Read 3869 times)
Offline drewcrane
t/a steering box
« on: September 26, 2008 - 09:19:03 PM »
i have had this in a box for years , is it worth any thing?
Re: t/a steering box
« Reply #1 on: September 26, 2008 - 09:23:50 PM »
Yeah, I've seen one on e bag hit over 700 before.
Offline AARCuda340+6
  • Southern Ontario
« Reply #2 on: September 27, 2008 - 02:05:40 AM »
Yes, very rare.  If you have the pitman arm too then your all set.   I had mine sent away to be repaired because you just can't find them anywhere.
You can call me RAY or RAYMOND or RAZOR or THE ZOR!
70 AAR Cuda
04 Rumble Bee
Offline moparclown
« Reply #3 on: September 27, 2008 - 06:08:23 AM »
The date casting on it shows it to be the same as mine,which would be to late for an AAR or T/A.A few (very few)71 340 cuda's were optioned with the T/A quick ratio steering box.
Offline drewcrane
« Reply #4 on: September 27, 2008 - 10:21:00 AM »
have you ever used yours, i did install mine for awhile until it developed a leak, it is a very fast ratio,i think about 2 1/2 to 3 turns lock to lock
Offline moparclown
« Reply #5 on: September 27, 2008 - 11:23:42 AM »
I need to have mine rebuilt,but I am a few years away from needing that done.
Tower Rat 95B
« Reply #6 on: September 27, 2008 - 02:24:55 PM »
 I bought mine 25 years ago , box, pitman arm and pump I paid 250 a big knot back then but even in the day they were hard to find........     I would not sell mine for less than a 1,500 dollars,  but that just  me  seems every time I go to buy something Mopar the price is always way way high.......
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #7 on: November 16, 2008 - 07:43:27 PM »
The faster ratio was from the pitman and idler arm.
2013 Tige' RZR 343hp
Offline ozrt4406
« Reply #8 on: November 17, 2008 - 01:15:53 AM »
so does that mean the steering box is the same as a std power steer box? why would they cast it t/a?
wouldnt the internals be different? ie worm / sector etc?
can anyone give me a coding off the build sheet for fast ratio steering ?. my t/a  build sheet reads.....
s77.... then underneath the 77 in the box it is stamped 4...so was this car std or fast ratio steering?
T/A AND R/T............... IM GREEDY.
Alaskan_TA
« Reply #9 on: November 18, 2008 - 09:49:43 PM »
The T/A box is different inside.
S74 is the broadcast sheet code for fast ratio steering.
After a certain point in 1971, the fast ratio boxes were used in all 1971 340 Cudas, & Challengers.
Tower Rat 95B
« Reply #10 on: November 18, 2008 - 10:13:39 PM »
 AlaskanT/A
   After the certain point in 71 did the 340 Cudas and Challengers  have the fast ratio with the T/A cast in to the body or did they just use a longer pitman and idler?
Offline JS27N0B
« Reply #12 on: November 18, 2008 - 10:37:39 PM »
I knew the full answers would arrive shortly.
Tower Rat 95B
« Reply #13 on: November 18, 2008 - 10:46:07 PM »
 Yea Alaskan T/A is fast :cooldancing:,,,,,,,,,,,,,,,,,   I think I am dense as wood cause I read it and it says Identical to the T/A cars but why do you need a special pitman and idler :clueless:,,,,,,,, would not identical T/A  pitman and idler be correct?
Alaskan_TA
« Reply #14 on: November 18, 2008 - 10:52:56 PM »
Because the T/A parts WERE special.  ;)
