uprade alternator & H4 light conversion
Author Topic: uprade alternator & H4 light conversion  (Read 8262 times)
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
Re: uprade alternator & H4 light conversion
« Reply #15 on: October 03, 2008 - 05:40:44 PM »
I was going to put a set of H4 tribar headlights on the high beam side. but when I went to install I saw I had to cut up the headlight door to make the larger bulb cone work. I didn't want to jut up anything to make them fit. Anyone know if a h4 that are bolt in. Or what can you do to make the H4 fit without cutting?
See the cone off the back of the bulb. That won't fit into the 73 housing. Everything else works but how can you make them fit?
« Reply #16 on: October 03, 2008 - 05:55:29 PM »
OOOOOOO  dat be a problem....I looked at fatrodders offerings & the back looks the same, maybe Michelle can give us a clue how they handled.
« Reply #17 on: October 03, 2008 - 05:57:26 PM »
They look great I would love to use them but I will not cut to make fit. Any help would benifit us both!!!  :woohoo:
« Reply #18 on: October 03, 2008 - 06:03:07 PM »
been a while since I looked at mine, but I found this pic..... jsut how close is it?   I would not mind opening mine up a smidge.
« Reply #19 on: October 03, 2008 - 06:57:48 PM »
For mine the inside diamiter of the cone on the light was the same as the hole in the headlight door. It was almost an 1/8 or more larger. But I may be a little off. Are the headlight holders the same on mine (73 challenger) as yours? If so I could just try to find another set to cut up.  :clueless:
« Reply #20 on: October 03, 2008 - 08:32:21 PM »
Donno...this was a pic I found on eBay.... I have a '73 also, I'll pull a bulb in a day or two & see.
Offline Aussie Challenger
« Reply #21 on: October 04, 2008 - 12:36:26 AM »
  Unfortunately I had to trim my buckets on my '70 Challenger, however mine is not  for show and I wanted the better lights.    :2thumbs:   :bigshades:
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #22 on: October 04, 2008 - 06:16:39 AM »
My husband said he did not cut anything they fit fine.They work awesome.
michele
Offline miketyler
    • www.miketyler.net
« Reply #23 on: October 04, 2008 - 08:35:32 AM »
yup, i dont remember having to open up my bucket holes either when I installed mine
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #24 on: October 04, 2008 - 09:08:17 AM »
 :popcorn:
Go Fast & Have Fun...
Offline duodec
« Reply #25 on: October 04, 2008 - 01:16:19 PM »
I used Carello H1 and H4 sets in my '71.  No mechanical changes needed though I had to do the relay update or the high beams would cause the switch circuit breaker to throw.
These were purchased through a foreign auto parts store in the '80s.  I do not know if they are available these days, but they are excellent quality and have a great light pattern with the OE H4 bulbs.
Offline ShelbyDogg
« Reply #26 on: October 05, 2008 - 10:04:27 AM »
I had to open mine up on my 70 Challenger. It was worth it along with the relays to get bright lights.
Offline miketyler
    • www.miketyler.net
« Reply #27 on: October 05, 2008 - 10:30:37 AM »
my experience may not have been pertinent since it was dual head lamp Cuda   :walkaway:
72' Cuda restomod
70 Mustang Mach 1
Offline the_engineers
« Reply #28 on: October 24, 2008 - 11:42:10 AM »
I think I used these guys...I'll have to check when I get home.  I looked at so many places for the 5.75" conversions.
http://www.slickcar.com/productdetails.asp?ProductID=1028
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #29 on: October 24, 2008 - 01:31:06 PM »
My car is originally a 1971 base Barracuda.  As part of the make-over process, I wanted to add roadlamps and do the H-4 conversion.  I followed the plan laid out by Goody, but for a 70-71 with roadlamps it needs to be modified to control the lighting correctly (i.e. not having roadlamps and brights on at the same time.)  Here's what I came up with.  I can provide pics as well, if needed.
I used standard four-post relays to control the low beams, high beams and road lamps.  I am switching back and forth between the high beams and road lamps with a five-post relay.  With my lights, the high beams will draw a total of 260W (65 W * 4), or 22 amps.  Pulling that much power, you'll want a 10 ga main feeding the circuit.  Not shown in the picture is the 30 amp fuse for the brights/road lamps and the 10 amp fuse for the low beams.
Brooks
1971 'Cuda 360
