Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Axles
« previous
next »
Print
Pages: [
1
Author
Topic: Axles (Read 1582 times)
300
Jr. Member
69 chevelle,67chevelle , 70 barracuda
Axles
on:
September 27, 2008 - 08:56:54 AM »
Hi. Replacing my 741 non suregrip with a 742 323 suregrip, would the axles and all other parts be usable. Thanks
Logged
hemiken
Sr. Resident
Hemi-fied Mopar in Australia
Re: Axles
Reply #1 on:
September 27, 2008 - 08:59:57 AM »
Changing the center will not change anything with the diff itself........ Axles will drop straight back in... the only problem you may have is if the yokes on each center section are different from one another, this will require a change of universal joint on the tailshaft.
Logged
1970 Barracuda (O^--^===|===^--^O)
1971 Barracuda (O O {]{]{]|[}[}[} O O)
1970 Challenger (O O [======R/T=] O O)
1971 Challenger (O O ===== ===== O O)
ShelbyDogg
Sr. Resident
Re: Axles
Reply #2 on:
September 27, 2008 - 09:18:20 AM »
Make sure that your sure-grip has the center pins in it, that the axles push against each other with. Without these you will not be able to adjust your axle end-play. (don't use green bearings)
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Axles
Reply #3 on:
September 27, 2008 - 12:30:05 PM »
make sure the inner cups on the sure grip are in line Before installing the center section , you can test this by sliding an axle into the side gears
Logged
300
Jr. Member
Re: Axles
Reply #4 on:
September 27, 2008 - 03:32:40 PM »
Thanks all, What a great site
Logged
troutstreamnm
Sr. Member
Re: Axles
Reply #5 on:
October 01, 2008 - 11:31:34 PM »
So what is the problem with the Green Bearings?
Logged
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Chryco Psycho
Administrator
C-C.com Guru
Re: Axles
Reply #6 on:
October 02, 2008 - 02:51:40 AM »
they do not take side loading as well as the tapered roller this can shorten the life of the brg & they often require either the center pin removed from the suregrip or the axles shortened when they are installed
Logged
moparmaniac59
Resident
Drive it like ya stole it!
Re: Axles
Reply #7 on:
October 02, 2008 - 08:41:22 AM »
Correct me here if I am wrong Rob, I believe the center section pins were only used on 1968 & earlier 742 case sure grip center sections?? Not sure of the exact year of the changeover, but do know the later years did not use the center block pins!!
Matt B.
Logged
Matt
71chally416
Resident
Re: Axles
Reply #8 on:
October 02, 2008 - 08:48:35 AM »
Quote from: troutstreamnm on October 01, 2008 - 11:31:34 PM
A Tapered roller bearing is WAY stronger than a ball bearing. That's why they use them on rearend pinions and carriers and the hubs of 4WD trucks. GM uses the rollers on their axels because they are CHEAPER.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Axles
Reply #9 on:
October 02, 2008 - 11:18:26 AM »
the clutch style sure grip uses the 2 small buttons , the later cone stlye has a floating center bock , typically the 742 had clutch & the 489 has cone but after 40 years a lot of clutch type have been swapped into later carriers
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Axles
