Author Topic: What Motor Oil Do You Use?  (Read 6436 times)
Offline AARCuda340+6
  • Southern Ontario
« on: September 28, 2008 - 02:04:48 AM »
I'm sure most of you out there use good oil for your cars but just recently I've read about most oils taking some additives out causing extreme wear to flat-tappet cams.  This year I used 15w40 diesel oil.
I've attached 5 pages from an article that describes what has been going on with the new oils of today and what you should buy to protect your motors.  Just some info I thought everyone should know.
You can call me RAY or RAYMOND or RAZOR or THE ZOR!
70 AAR Cuda
04 Rumble Bee
Offline ROMI
  • 71 Challenger R/T 340 4 speed, Lapeer Michigan
Re: What Motor Oil Do You Use?
« Reply #1 on: September 28, 2008 - 07:44:32 AM »
Valvoline VR1 + Lucas Oil Additive
Offline GoodysGotaCuda
« Reply #2 on: September 28, 2008 - 07:49:00 AM »
I run 15w-50 Mobil 1 full synthetic, it has around 1,200ppm off the top of my head. About $24 for 5qts at wal-mart
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline drewcrane
« Reply #3 on: September 28, 2008 - 08:22:09 AM »
im running royal purple,since it came out, no issues :bigsmile:
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #4 on: September 28, 2008 - 08:58:02 AM »
royal purple
« Reply #5 on: September 28, 2008 - 11:33:56 AM »
Or does this have less to do with polution & is more of a subversive way to get all the gas guzzing older cars off the road so we have to go buy new  vehicles to support the struggling car industry  :poopoke:
Offline nqkjw
« Reply #6 on: September 28, 2008 - 11:56:54 AM »
I use 30 weight diesel oil. :naughty:
Most diesels still use flat tappet cams and therefore diesel oil has still got the right zinc content. :thinkerg:
Burnouts are cool but Traction is the Action
« Reply #7 on: September 28, 2008 - 12:10:53 PM »
not true , Castrol 15 40 does but most diesel oils are SM rated now so reduced  Zinc Phosphorus content
Offline pink panther
« Reply #8 on: September 28, 2008 - 01:57:01 PM »
Royal purple 10W40
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #9 on: September 28, 2008 - 04:22:00 PM »
Royal purple 10W40
:iagree:  Switched to this last year from Redline Oil
The only thing that caught me off guard with Royal Purple is the fact that it is really purple when it comes out of the bottle.
Offline RaptorF229
  • A work in Progress
« Reply #10 on: September 29, 2008 - 12:11:32 AM »
10v40 amsoil. Amsoil 10-40 and 20-50 still have high zddp.
Offline duodec
« Reply #11 on: September 29, 2008 - 12:15:15 AM »
I have a bunch of the gallon jugs of pre-castrated Rotella.  Hopefully I'll have the car driving before it "times out" on the shelf.  If not I have a neighbor who can use it.
« Reply #12 on: September 29, 2008 - 04:53:25 AM »
That's what I use, although Royal Purple is good too for those of us that like to spring for $ynthetics.    :money:
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #13 on: September 29, 2008 - 09:14:02 AM »
I`ve just been adding the Comp cams break in lube at every oil change as they recommend.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline resq302
« Reply #14 on: September 29, 2008 - 09:27:14 AM »
Ive been using Valvoline VR1 race oil 20w-50 (its the only weight that pep boys carrys in the race oil).  I would prefer the 10w-40 race oil as it would free up some horse power but at the sacrifice of my engine, i'll have to stick with the thicker oil till I can find a stash of the other race oil weights.
