Author Topic: What carb do you suggest for my 70 Challenger R/T 383?  (Read 1245 times)
Offline cdecristo
    • My Challenger Website
« on: September 29, 2008 - 05:08:05 PM »
I have a rebuilt 383 with a mild cam . I have the original carb that i sent to be restored by a local guy . He did not do a very good job. The carb does not work very well. I know there are guys who can do a good job restoring the carb, but I might just leave it and get a new carb. Which one do you guys recommend? The original carb is a Holley 4369. I posted this on moparts too, I just wanted to get more opinions. Thanks
1970 Dodge Challenger R/T SE
Offline 71chally416
    • The Streetwalker
Re: What carb do you suggest for my 70 Challenger R/T 383?
« Reply #1 on: September 29, 2008 - 05:35:45 PM »
I can't think of a better carb for a mild 383 for the $$$ than a 800 thunder AVS.  :2thumbs:
Offline 72bluNblu
« Reply #2 on: September 29, 2008 - 05:49:29 PM »
I would go with at least a 750cfm for a 383, I plan on using a 770 cfm holley street avenger on my 340. I'm not planning on a mild cam though... :biggrin:
Offline 73Chally
« Reply #3 on: September 29, 2008 - 05:51:35 PM »
For a mild cam, pretty much stock motor, I think you should look more in the 650-700 CFM range.  I think 800 would be too much.
« Reply #4 on: September 29, 2008 - 05:55:28 PM »
Do you have a 4-speed or auto? Something in the 750 range would work well for you.
Offline 72bluNblu
« Reply #5 on: September 29, 2008 - 06:09:53 PM »
Not so sure about that, Mopar Muscle did a 340 build and started with an all stock motor, they bolted an 800cfm AVS thunder on it with no tuning and gained 35 hp and 22 ft/lbs of torque, just straight out of the box. The only thing was that it was an earlier 340, so it had stock 10:1 compression. Still, I would think as long as the compression on the 383 is around 9:1 with a mild cam a 750 should be very workable.
Offline cdecristo
« Reply #6 on: September 29, 2008 - 06:10:43 PM »
Sorry It's an auto. I would prefer to stick with a Holley. Should It have an electric choke? Any model in particular? Thanks
« Reply #7 on: September 29, 2008 - 06:21:24 PM »
The Holley Street Avenger 770 should be your ticket. The electric choke is far more easier to deal with than a manual choke.   :grinyes: From personal experience, you will probably have to jet it down some in the primaries, but that isn't a biggie.
