Author Topic: Good converter for low compression 340  (Read 1482 times)
Offline mikerallye
« on: September 29, 2008 - 09:23:32 PM »
What would be a decent converter for a low compression 340 challenger. I have rmp airgap intake, 750 carb, and headers. 323 rear. its the torqueflite. It is slow taking off.     :clueless:
Offline 71chally416
    • The Streetwalker
Re: Good converter for low compression 340
« Reply #1 on: September 29, 2008 - 09:26:42 PM »
What tranny and rear gears are you running?
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: September 29, 2008 - 09:32:15 PM »
What cam are you running?
1996 Dodge Viper GTS Coupe
Offline heminut
« Reply #3 on: September 29, 2008 - 09:33:31 PM »
It's in his post, torqueflite and 3.23 gears. I would use a 2000-2500 stall.
1970 5.7 Hemi Cuda
Offline 72hemi
« Reply #4 on: September 30, 2008 - 02:32:11 AM »
But if he is running a cam that has a powerband that starts at 1500 or below then I don't think I would get a stall.
Offline tactransman
« Reply #5 on: September 30, 2008 - 10:00:31 AM »
Torqueflite could be 727 or 904. What are your cam specs? I bet it is too big.
Terry-tactransman
Union, Mo.
Offline 71chally416
    • The Streetwalker
« Reply #6 on: September 30, 2008 - 11:14:45 AM »
BIG difference on a low compression small block.  There's a good reason they used the 904 with the 2.74 low gear in the 318's in the later years. One of those with even a stock convertor and a 3.91 or 4.10 gear would make a world of difference, even with a decent cam. A convertor change won't.  :2cents:
Offline mikerallye
« Reply #7 on: October 01, 2008 - 10:55:01 PM »
It is a basically stock 73 challenger rallye. 14" wheels 245s, eddy RPM airgap, headers, 3.23 rear suregrip, 750 performer, cam is stock .429 int .444 ex or .286 and .296 at lifter. It will burn the tires for about 75 feet and chirps the tires in third sometimes. Just feels sluggish getting started. Is it a 727 or a 904? Seems like it changes into second gear way early? thanks   :burnout:
Offline 71chally416
    • The Streetwalker
« Reply #8 on: October 01, 2008 - 11:43:31 PM »
So it smokes the tires for 75 feet and it's sluggish in 1st gear?  Maybe because it's not hooking up??  :clueless:
You can tell a 904 from a 727 by the shape of the pan. The one on top is the 727. The 904 is square with one angled corner like on the bottom.
Offline mikerallye
« Reply #9 on: October 02, 2008 - 12:53:03 PM »
It's like there is a pause before the tires brake loose. Then all   :swear:  breaks loose. little slow before things start to happen.  :dunno:
Offline tactransman
« Reply #10 on: October 02, 2008 - 12:58:15 PM »
Sounds like engine tuning problems.
Terry-tactransman
Union, Mo.
Offline 71chally416
    • The Streetwalker
« Reply #11 on: October 02, 2008 - 02:32:48 PM »
 :iagree:  Maybe your accelerator pump. Look down in the carb and make sure it squirts gas with the slightest movement of the throttle.
