Author Topic: Replacing powersteering gear box  (Read 1995 times)
Offline RaptorF229
  • A work in Progress
« on: September 30, 2008 - 10:23:58 AM »
My new firmfeel. Gear box came in yesterday. I'd like to put it in tomorrow. Does anyone have any words of wisdom on how to take it out and install the new one?
Re: Replacing powersteering gear box
« Reply #1 on: September 30, 2008 - 10:35:15 AM »
not to tough , headeers will make the job worse , you will need a pitman arm puller unless you got a new one with the box
Offline Robb
« Reply #2 on: October 02, 2008 - 01:51:02 AM »
ROLL PIN !   watch out.
get a BFH and a proper sized punch.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline RaptorF229
« Reply #3 on: October 02, 2008 - 02:02:27 AM »
well I got it done today. I need to grease the new idler arm. Also there seems to be a little play when I turn towards the right. Turning to the left seems fine. Any thoughts? I also replaced my torque converter today. At the end of all this I realized that I hate headers.
Offline loco440
« Reply #4 on: October 02, 2008 - 06:42:56 AM »
Off track a bit what box did you get? Im still wondering weather to go Firm feels STG 3 or a bit cheaper Steer and Gears X firm,could you give us a bit of feed back on how you like it.
Offline RaptorF229
« Reply #5 on: October 02, 2008 - 09:44:41 AM »
I went with the firm feel stage 2 and the fast ratio pitman arm. I also had to change the idler arm to match up with the new pitman arm. I like the two aloe better than the original but I also think that a 3 might be even better. I was going to go with steer and gear but they said it would be awhile before I would get it. Me being the impatient person that I am went and bought the firm feel unit. I will say that the firm feel guys were very nice and helped me everytime I gave them a call for help.
Offline duodec
« Reply #6 on: October 02, 2008 - 11:59:32 PM »
Does it happen at a stop?  If so, can you look at the components from under while someone else turns the wheel?  See if anything is loose or shifting.  Make sure the mounts on the K-frame are tight (they can crack and if you didn't clean the frame around where the box mounts you might miss it).  Idler arm mounts too, or the holes in the idler arm mount might have hogged out if the old one was loose or damaged.   Also, did you properly purge the system, using the method in the service manual (or perhaps instructions with the new box)?
Offline RaptorF229
« Reply #7 on: October 03, 2008 - 01:25:29 AM »
Thanks for the help. I bolted the steering column too high and it was rubbing the firewall or the bracket by the firewall. well either way I got it fixed. Thanks again everything is now working great.
Offline 500Stroker
« Reply #8 on: October 03, 2008 - 01:37:32 AM »
I had a steer and gear level 2 hated it.  Too loose.  This year I swapped it out for a Firm Feel stage 3.  Best change I have made.  Big difference.  Don't let anyone tell you 3 is too stiff.  It is perfect.  No play at all, very responsive.  Reminds me of my old 79 Trans Am.
Offline RaptorF229
« Reply #9 on: October 03, 2008 - 01:41:01 AM »
i agree with loco even though I'm happy with the stage2 I know i can handle the stage three.
Offline Robb
« Reply #10 on: October 03, 2008 - 02:18:38 AM »
agreed.
I have the stage 2 in the Challenger , and my T/A steers heavier.
