Author Topic: Tranny Acting Weird  (Read 1909 times)
Offline CUDA JAS
  • vroooooom!
Tranny Acting Weird
« on: September 30, 2008 - 09:43:06 PM »
So I finally drove my cuda after 15 years.
I am running an XV kickdown cable, and with it hooked up the tranny is acting weird, you have to rev it up to get it in gear..and driving down the road,  it feels like it is poping in and out of gear. At idle it comes out of gear and you have to rev it up to get it to go.
I unhooked the kickdown and it works much better, stays in gear going down the road and at idle, but of course you have to manually shift it.
Is this just a kickdown adjustment, or am I into something bigger?
Trans is out of 1980 New yorker and is a lock up unit if that matters.
Jas
74 'cuda 360/727
Just call me a gearhead!
Offline 422STROKER
  • Member Since 6/3/06
Re: Tranny Acting Weird
« Reply #1 on: September 30, 2008 - 09:46:37 PM »
KD adjustment, with the cable on mine it was a very fine adjustment to get it right.
Tom
BTW do not continue to drive it that way you will burn up the trans without the KD.
Tom
Offline 71chally416
    • The Streetwalker
« Reply #2 on: September 30, 2008 - 10:21:57 PM »
You have a lockup 727 out of a New Yorker that had a 360??  :clueless:
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: October 01, 2008 - 08:18:16 AM »
yep, was in it when I got the car...better than the origional 318 I guess.
74 'cuda 360/727
Offline tactransman
« Reply #4 on: October 01, 2008 - 08:23:22 AM »
The TV adjustment has nothing to do with it going into gear. It sounds like it is low on fluid. Did you check it idling in NUETRAL?
Terry-tactransman
Union, Mo.
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: October 01, 2008 - 09:02:22 AM »
Tom
So any advie you can give me on the adjustments???
I hope to have some time on sat / sun to work on it, but with the onset of my daughters hockey season, I may not get much time.
74 'cuda 360/727
Offline tactransman
« Reply #6 on: October 01, 2008 - 09:15:48 AM »
Check your fluid first,I think you are gonna find it is low and maybe cure all your troubles. The adjustment is as follows: With the carb all the way to the floor,the TV lever on the trans should be maxed out all the way back.
Terry-tactransman
Union, Mo.
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: October 01, 2008 - 10:20:57 AM »
 I did check the fluid, it was low, and I filled it up, but I will check it again, I may have done it with the car in park... :clueless:
74 'cuda 360/727
Offline 422STROKER
« Reply #8 on: October 01, 2008 - 02:42:12 PM »
With the cable on mine and fluid at correct level it would shift fine until the 2-3 shift if the KD was just a smidgen tight on the aftermarket cable.  When I loosened it up the shift was mint, I'm talking 1/16" of an inch here.  Before I would have to lift a bit to get it in 3rd at a mild cruise.
Tom
Ya if you checked the level in park it will be low too in Nuetral
Tom
Offline 71chally416
    • The Streetwalker
« Reply #9 on: October 01, 2008 - 02:50:44 PM »
If all else fails, follow the directions written on the dipstick  :2thumbs:
Offline CUDA JAS
  • vroooooom!
« Reply #10 on: October 14, 2008 - 12:50:49 PM »
Yep in the heat of the moment I forgot to read the dipstick!!!
I was low on fluid, that seems to have fixed the problem...car is workign much better now!
Thanks guys! :ylsuper:
Jas
74 'cuda 360/727
Offline tactransman
« Reply #11 on: October 14, 2008 - 02:14:31 PM »
 :clapping:
Terry-tactransman
Union, Mo.
Offline CUDA JAS
  • vroooooom!
« Reply #12 on: October 14, 2008 - 03:20:57 PM »
:clapping:
Yeah I was like  :-[, then I was like  ::), and now I am  :clapping: :ylsuper: :woohoo: :burnout:
74 'cuda 360/727
