Author Topic: A-833 QUESTION  (Read 4330 times)
Offline bluecuda360
A-833 QUESTION
« on: October 01, 2008 - 08:44:28 PM »
Can somebody answer this? What difference is there between a small block B/E body 4 speed trans and big block B/E trans? Is it the bearing retainer size? :clueless:
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: A-833 QUESTION
« Reply #1 on: October 01, 2008 - 08:58:18 PM »
The input shaft bearing is larger on the big block 4 speed. There is also a hemi 4 speed that also has an 18 spline input shaft instead of the 23 spline.
1996 Dodge Viper GTS Coupe
Offline bluecuda360
Re: A-833 QUESTION
« Reply #2 on: October 01, 2008 - 09:22:55 PM »
Okay, so if the bearing retainer is 4.80 it is strictly for a big block? And if it is 4.30 it a small block?The reason I'm asking is I have a 74' 360 4 speed Cuda.I never had the original trans for it, and the bellhousing that came with the car (in boxes)is for a 72'-73' 318 -340 #3515734 .It has the small retainer size in it.I dragged home a 4 speed it has the 4.80 opening.Is the 74' bellhousing #3743959 a unique piece? If so what is different about it? It looks like I have trans and bellhousing that I cant use,am I correct?Thanks for any help or suggestions!
Re: A-833 QUESTION
« Reply #3 on: October 02, 2008 - 02:50:15 AM »
not all big blocks used the bigger retainer , the 74 360 may have used th elarger retainer as well , the set up you have is a mismatch but you could bore the bel out to 4.80or sell it & buy a bel with the 4.80 hole
Offline bluecuda360
Re: A-833 QUESTION
« Reply #4 on: October 02, 2008 - 05:48:02 AM »
Thats what I'm hoping is that the 74' bellhousing is a 4.80.I'm trying to locate one,not having much luck.I know its kind of an oddball year.Thanks for the help.
Re: A-833 QUESTION
« Reply #5 on: October 02, 2008 - 07:05:36 AM »
Why don't you just buy a different bearing retainer and swap it. http://www.passionperformance.com/c42.html
Re: A-833 QUESTION
« Reply #6 on: October 02, 2008 - 11:16:01 AM »
you can geta a 4.80 retainer to fot the smaller bolt pattern but not the other way there is now way tro fit the the smaller 4.35 reatiner to the 4.80 trans
Offline bluecuda360
Re: A-833 QUESTION
« Reply #7 on: October 02, 2008 - 07:45:00 PM »
Yep, the retainer on my trans has the larger bolt circle 4.16 ,cant get the smaller retainer with that bolt circle,like Chryco said.Still searching for that 74' bellhousing to see what that looks like.
Offline matt63
Re: A-833 QUESTION
« Reply #8 on: October 10, 2008 - 07:59:37 PM »
When I bought my Lakewood scattershield it came with a spacer ring to accommodate 2 sizes of input bearing OD's.  I don't know if it is sold separately or not but could be made up easy enough if you have the smaller housing.
Matt in Edmonton
'68 Valiant
Offline Aussie Challenger
Re: A-833 QUESTION
« Reply #9 on: October 11, 2008 - 08:48:08 AM »
  take your bellhousing to a good machine shop with the front retainer housing and they will machine your bell housing.   :2thumbs:
Offline 73EStroker
Re: A-833 QUESTION
« Reply #10 on: October 12, 2008 - 01:22:13 PM »
I had my 426 Max Wedge bellhousing (cast iron 10-1/2") machined out to fit the OD A833 and it seems fine. The machine shop should have a lathe called a bridgeport lathe. This keeps the bellhousing stationary and the cutting tool turns.
Barry (Salmon Arm)
Offline Jim
Re: A-833 QUESTION
« Reply #11 on: October 24, 2008 - 10:08:54 PM »
I was about to post a similar question myself when I came across this thread.
I've got a big block 23-spline four speed and I want to (possibly) run it behind a small block. So I just either need to swap to the smaller bearing retainer, or enlarge the bell housing hole, correct?
I'm still exploring engine options on the Cuda.
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline 71chally416
    • The Streetwalker
Re: A-833 QUESTION
« Reply #12 on: October 24, 2008 - 10:20:07 PM »
If I was going to enlarge the hole in a bellhousing I'd use a Mill, not a Lathe. It has a table to clamp the part down.  :dunno:
« Last Edit: October 24, 2008 - 10:23:45 PM by 71chally416 »
Offline LAA66
Re: A-833 QUESTION
« Reply #13 on: October 24, 2008 - 10:46:31 PM »
 Doesn't the bellhousing and trans need to be indexed to the crankshaft also?
Re: A-833 QUESTION
« Reply #14 on: October 24, 2008 - 10:51:49 PM »
 You need to  get hold of a small block bell housing, measure the input retainer dia. on your gearbox and try to find a bell housing with that dia. opening. If you cannot find one and it is smaller then it will have to be machined larger. If retainer is smaller an adaptor/spacer ring will have to be either made by a machine shop or try to find one.   :2thumbs:
