Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
A-833 QUESTION
« previous
next »
Print
Pages:
1
2
Author
Topic: A-833 QUESTION (Read 4301 times)
matt63
Sr. Member
Re: A-833 QUESTION
Reply #15 on:
October 26, 2008 - 12:40:10 PM »
Quote from: LAA66 on October 24, 2008 - 10:46:31 PM
Doesn't the bellhousing and trans need to be indexed to the crankshaft also?
You can mount the bellhousing on the engine and check runouts in the bore. You have to mount the dial indicator on the crank flange and rotate the crank. I used a mag base but some sort of clamp would have been better. I bought one of those mini finger type dial indicators for the job. If runouts are bad you need to use offset dowels to center the bellhousing which is what I did with the Lakewood housing. It's a tedious process.
Logged
Matt in Edmonton
'68 Valiant
Changin Gears
Sr. Member
Re: A-833 QUESTION
Reply #16 on:
October 26, 2008 - 12:46:17 PM »
If you open the bellhousing up does it take out the clutch fork pivot mounting bolt holes?
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
A-833 QUESTION
