Part list for 4 spd swap
Author Topic: Part list for 4 spd swap  (Read 4427 times)
« on: April 18, 2004 - 03:14:59 AM »
 Online
9 sec Cuda
      « on: Wednesday • Apr 14, 2004 • 12:39:06 AM »
4 spd conversion parts
Pedals
firewall support bracket
pushrod [pedal to Z bar ]
Z bar [different widths for big & small block ]+ nylon bushings
Frame pivot bracket
pivot balls
adjuster link [Zbar to fork ]
release fork
belhousing or blashshield
release brg
clutch assbly
Flywheel [requires differnt crank bolts than flex plate ]7/16 x 1"
pilot bushing or brg
differnt crossmember , on pre 69 B bodies
floor hump
tranny
shifter mechanism & rods & levers
shift handle + boot & ring
clips to hold pushrod & adjuster to Z bar
Many of these parts are still available from Mopar , other parts are available from Brewers performance , Passon perf , Keisler , Mcleod , Lakewood , Hays ,  Ram , Mancini
« Last Edit: April 27, 2006 - 12:44:13 AM by Chryco Psycho »
Offline Carlwalski
Re: Part list for 4 spd swap
« Reply #1 on: July 05, 2004 - 02:58:15 PM »
Good effort Chryco, a top idea.  ;)
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
