Author Topic: Removing the glue from under the vinyl top  (Read 1936 times)
Offline rallye5.7
« on: October 02, 2008 - 09:09:35 PM »
I took off the vinyl roof on my car this week and was wondering if anyone has an easy way to remove the glue. Just rubbing it seems to work but I'll wear the skin off my fingers before the roof is done. I tried some varsol and thinners but that just spreads it around into a sticky mess.      Any ideas??
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
Re: Removing the glue from under the vinyl top
« Reply #1 on: October 02, 2008 - 10:04:35 PM »
adhesive remover or goo-gone
Offline duodec
« Reply #2 on: October 03, 2008 - 12:39:35 AM »
If those do not work you could also try (carefully after checking for paint damage) WD-40 or Kroil penetrants; they can do a pretty good job on adhesives.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #3 on: October 03, 2008 - 02:51:38 AM »
 :iagree: with using WD-40.
I resized your avatar so it can be seen without scroll bars.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline rallye5.7
« Reply #4 on: October 03, 2008 - 09:25:25 AM »
Thanks hooD, now if I can just figure out how to replace it with the old one.
Offline mrob
« Reply #5 on: October 03, 2008 - 11:29:28 AM »
I've used contact cement remover sold at hardware stores to remove vinyl flooring. The stuff I bought was powerful and easily removed the glue, but you need to be careful about the paint on the roof.
Offline rallye5.7
« Reply #6 on: October 03, 2008 - 09:50:48 PM »
Ok here's what I found. I used a surface cleaner made by sikens (I'm sure other paint manufacturers have similar products) and after wiping it on with a cloth to soften it up I used a nylon pot scrubber pad. In 1/2 hour I cleaned around the window openings and 1/2 the roof.
The glue just clumps up and is easily vacumed.
By the way my paint guy wasn't too fond of the WD40 idea, something about residue in the seams mixing with paint prep.
Offline hooD
  • detroit iron
« Reply #7 on: October 05, 2008 - 12:13:28 AM »
First, download the new resized .jpg file of your car and save it to your hard drive.  Then.....
-Click the PROFILE tab
-then go to FORUM PROFILE INFORMATION
-browse and upload your new .jpg file of your car
-be sure to click CHANGE PROFILE at the bottom of the page to save changes
-Larry
1973 'CUDA 340
original owner
37,117 miles
