rear sway bar
Author Topic: rear sway bar  (Read 1417 times)
Offline 300
  • 69 chevelle,67chevelle , 70 barracuda
rear sway bar
« on: October 03, 2008 - 05:22:55 AM »
HI. Is the rear sway bar on a 70 cuda bolted or welded to the sub frame.Car never had one, I,m putting one on Thanks. Any pics for locates of brackets.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: rear sway bar
« Reply #1 on: October 03, 2008 - 06:17:18 AM »
it bolts to the frame rails.
Go Fast & Have Fun...
Offline 300
Re: rear sway bar
« Reply #2 on: October 03, 2008 - 06:24:55 AM »
Thanks. Great site
Offline ksierens
    • 70 Challenger Resurrection
Re: rear sway bar
« Reply #3 on: October 03, 2008 - 12:36:37 PM »
Here is an answer I got when I was mounting mine.  Because the origional u bracket that mounts to the frame is tapered, it pretty much locates itself.
http://www.cuda-challenger.com/cc/index.php?topic=31726.0
Kurt - SE Michigan
Re: rear sway bar
« Reply #4 on: October 03, 2008 - 12:42:17 PM »
the original used self tapping bolts , you can also bolt right through the frame rail
Offline ksierens
Re: rear sway bar
« Reply #5 on: October 03, 2008 - 02:05:37 PM »
 :iagree:  I went through the rails, best thing would be to weld bushings through the frame first so as not to crush the frame.
Kurt - SE Michigan
Re: rear sway bar
« Reply #6 on: November 23, 2008 - 07:47:16 PM »
I was going thru some hardware today and I am pretty sure that this is what the rear sway bar bolts are.
To my knowledge, the exact reproductions or originals are not available.
Offline noschevys
Re: rear sway bar
« Reply #7 on: December 01, 2008 - 03:55:25 PM »
The bolts (8 pcs.) are 5/16 -18 x.70"long Hex washer head screws with paint cutter and CA point.  Silver Zinc finish grade 2 or 5.  The head markings are a 3/4 circle with lines at the 3,6,9 loaction.  The bottom of the hex washer has teeth.
Re: rear sway bar
« Reply #8 on: December 01, 2008 - 11:58:15 PM »
Here's what the Mopar bolt guide says.
One on the left is shaped like the letter P.
« Last Edit: December 01, 2008 - 11:59:47 PM by Topcat »
