Misc resto and performance parts
Author Topic: Misc resto and performance parts  (Read 1338 times)
« on: October 04, 2008 - 11:46:11 AM »
Assorted OEM, NOS, repro, and aftermarket parts for mopars. Pictures available for any item. Parts from Mopar Performance, American Muscle, AR Engineering and more. You pay shipping on most items from 80907. PM me here or email at highplains@comcast.net. Willing to ship international. I can also accept Paypal.
TC
list
$250.00   66-70 B body clutch pedal assy, rebuilt
$180.00   Viper caliper brackets
$150.00   Wilwood caliper adapter brackets
$100.00   66-70 B body clutch pedal assy, needs rebuilt
$115.00   B/E adjustable steel strut
$115.00   B/E aluminum strut
$80.00   66-70 B 4spd tunnel cover, used
$75.00   adj pinion snubber 8 3/4
$65.00   alum shackle bushing
$50.00   Super Bee Emblem — Grille (1969 Super Bee)
$50.00   Clutch Linkage Shaft Service Kit (B- and E-Body)
$50.00   SB tall throttle bracket
$50.00   low deck big block tall throttle bracket
$50.00   W2 tall throttle bracket
$50.00   Abody  Lwr arm poly pivot
$50.00   RB block tall throttle bracket
$50.00   axle shim set
$50.00   Sure grip clutch kit
$45.00   kickdown cable style bracket
$45.00   BB throttle cable
$40.00   T-bar tool
$36.00   R/T Nameplate Emblem — Grille (1970-71 E-Body)
$35.00   Master cylinder adapter
$35.00   lwr cntrl arm pivot tool
$35.00   lwr cntrl arm bushing tool
$30.00   C body washer bottle
$30.00   B/E ball joint socket
$30.00   Hood Pin and Cable Kit
$30.00   “440 6-bbl” Hood Decal
$30.00   Upper ball joint seperator
$25.00   Fender Cover, Direct Connection, White on Black
$25.00   t-bar adjuster
$25.00   J bolt for gas tank straps
$25.00   8.75 rear thrust washer kit
$24.00   BB chrome dist hold down
$15.00   battery hold down strap kit 60-65 all
$20.00   Lower control arm bracing plate
$20.00   Lower control arm bracing plate, late B
$20.00   Miller Racing banner
$20.00   Winston racing banner
$20.00   67 GTX back up lenses
$15.00   Standing RR w/ helmet decal
$20.00   big block throttle return set for tall linkage set
$15.00   BB header gasket set
$14.00   transmission output seal
$12.00   5/16 fuel tank filter sock
$10.00   upper control arm cam bolt assy
$10.00   coupler-steering pot rebuild package
$10.00   heater hose bracket 67-68 big block w a/c
$10.00   3/8 tank filter sock
$10.00   chrome coil bracket
$10.00   74 fender mounted turn signals
$9.00   Street Hemi Orange Engine Paint
$9.00   Red engine enamal
$5.00   spare tire hold down wing nut
$5.00   SB exhaust manifold sleeve nuts
$5.00   70-74 batt J bolt hold downs
$5.00   NOS big block throttle return set
$3.00   valve lash decal
$3.00   gasket-8-3/4 axle foam-backing plate to axle
$3.00   Direct Connection large decal
$5.00   OE ignition key blank
$5.00   OE trunk key blank
$1.00   5/16 corbin clamp
$1.00   3/8 corbin clamp
Offline Red R/T
Re: Misc resto and performance parts
« Reply #1 on: October 08, 2008 - 08:07:19 PM »
HP2, do you still have the R/T grille emblem and what condition is it in?  I also need the spare tire wing nut.  Thanks, Chuck
1970 Challenger U code R/T SE
« Reply #2 on: October 09, 2008 - 07:14:05 AM »
Still have them.
Offline vert
  • Looking good, Billy Ray! Feeling good, Louis!
« Reply #3 on: May 26, 2009 - 09:59:48 PM »
What do the Viper Caliper brackets fit?  A Viper?  An Ebody? A Bbody/
Thanks?
71 Barracuda | Hemi idling | Hemi Dyno pull
« Reply #4 on: May 27, 2009 - 12:46:40 AM »
The Viper bracket kit is design to bolt to 74-76 drum brake spindles under classic mopars. Typically this would mean late A, late B and FJM body. I do not know if they would work with earlier A spindles. For an additional $50, I also have the bearing spacers to allow you to use 11.75 rotors on the earlier (pre 74) small bearing spindles.
