The Thermoquad is a great carburetor, but must be understood to be properly tuned. There is a book about the Carter carbs that will help you here, called Super Tuning and Modifying Carter Carburetors, from S-A Design (SA11). Everything I didn't already know about Carter carbs, it taught me. Air valve tension, metering rod hanger spring height, and a myriad of other specs and adjustments are covered in depth. If you need some specific advice on driveability problems, ask here, and somebody will be able to help. It looks great.
